Head Stud Trouble
Old Feb 23, 2013 | 06:04 PM
Ls_Notch's Avatar
Default Head Stud Trouble
So I was going through the final torque sequence and was on the final ARP studd and the damn think broke off in the block! Luckily it was one of the short ones and I should be able to drill it and get it out with a easy-out but I cant believe it broke, have any of you had this happen? Does anyone have a single stud they could sell me?
Old Feb 23, 2013 | 08:19 PM
S10xGN's Avatar
You can buy individual parts straight from ARP, or from Summit or Jeg's if you know the exact part number. BTW, get that torque wrench calibrated! Never heard of an ARP bolt/stud failure due to anything but a faulty wrench...
Old Feb 23, 2013 | 08:40 PM
Ls_Notch's Avatar
Yea it was a brand new one from O'Rileys and the other head torqued up perfect and all the other bolts did to, this was the last one I had to do... Seem like it always happens when your almost done.
Old Feb 23, 2013 | 09:09 PM
Ls_Notch's Avatar
Anybody out there know the part # for the Short studs in the up to 03 kit? I think they might be the same length as the 04+ ones
Old Feb 23, 2013 | 09:42 PM
badazz81z28's Avatar
What short stud? The 8mm?
If so, Yes the studs are the same for pre '03 and '04+
BTW the torque on that stud is very low. Did you lubricate the threads with ultra torque lube? Made sure the stud bottom'd out in the block finger tight?
Old Feb 23, 2013 | 10:23 PM
Ls_Notch's Avatar
It was one of the short big studs that broke and it was bottomed out
Old Feb 23, 2013 | 10:29 PM
Burken01's Avatar
the top little bolts are 25lbs, thats crazy that it broke on such a low torque rating....
the more I work on these engines the more I start to see some crazy ****.
Old Feb 23, 2013 | 11:56 PM
BattleSausage's Avatar
You haven't been around long enough. Even ARP on occasion has a crap bolt fall through QC.
Old Feb 23, 2013 | 11:59 PM
Burken01's Avatar
ha true that.. Im keeping my eyes open now
Old Feb 24, 2013 | 12:36 AM
Ls_Notch's Avatar
Hopefully that crap bolt didn't screw me over too bad...
Old Feb 24, 2013 | 01:09 AM
Burken01's Avatar
what did you torque it to?
it should come out with an easy out since they are finger tight in there..
as long as the thread is fine your good to go, and in worse case senario get a helicoil kit for it..
Old Feb 24, 2013 | 06:05 AM
RezinTexas's Avatar
give ARP a call and explain what happened. they will likely send a replacement for free.
Old Feb 24, 2013 | 07:40 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Yep. Crazy that it happened too. Lots of guys even take the little ones to 28#. Did you used the ARP lube?
Either way just call ARP. You don't need a part #... They'll know what to send you.
Old Feb 24, 2013 | 09:19 AM
Ls_Notch's Avatar
It wasn't one of the small ones across the top, it was one of the main ones. Luckily it was one of the short main ones though so it's only a inch or so down in the block. Gonna try to drill it and pull get it out today, hopefully it works.
Old Feb 24, 2013 | 10:03 AM
If it was installed properly, it should simply spin right out with ease. Where did it snap? Flush with the block or down in the hole?
Old Feb 24, 2013 | 12:15 PM
Ls_Notch's Avatar
Got it out! Drilled the center and used a easy-out and came out pretty easy. Calling ARP in the morning and getting a new one, hopefully it will work out better this time.
Old Feb 24, 2013 | 04:01 PM
dr_whigham's Avatar
The Scammer Hammer
Good to hear, brother!
Old Feb 24, 2013 | 04:56 PM
Hehe, at least it came out! I'm sure ARP will take care of you...willing to bet they will want that bolt back to QC it though. Good save.
Old Feb 25, 2013 | 05:02 PM
Ls_Notch's Avatar
Called ARP today and they are sending me a new stud free of charge. More than happy with their products and customer support, may cost a little more but way worth it to me.
Old Feb 25, 2013 | 08:31 PM
hiltsy855's Avatar
Good to hear. Glad you got it worked out.
