LS7 and Tac system issues
Old May 26, 2013 | 11:37 AM
FreshDA9's Avatar
Default LS7 and Tac system issues
Hello I have a 98 corvette in which uses the Throttle Actuator Control (TAC) system. I currently have a LS7 swap going in and am having a hard time finding a throttle body that is flanged LS7 but works with the corvettes TAC! Does anyone make such a throttle body? Thank you.
Old May 26, 2013 | 11:54 AM
Jason Haines @ LPE's Avatar
LS1Tech Sponsor
Default 90mm LS1/LS6 4 bolt throttle body
We have one available:
http://www.lingenfelter.com/mm5/merc...=#.UaI9B9KsiSo
I think we give a core credit for the return of the stock throttle body so that is part of why the cost is so high (new replacement throttle bodies are around $450 now).
Old May 26, 2013 | 06:42 PM
FreshDA9's Avatar
Thank you Jason,
quick question its labeled as LS1,LS6 but it does look like a LS7 flange. Just wont to be positive that its for a LS7.
So if i was to send the core return are you saying the core is $450 return when sent back to you?
Thank you!
Old May 28, 2013 | 01:00 PM
LS1Tech Sponsor
Default 90mm throttle and core credit error
My mistake on this. Due to the problems of having to test to make sure the cores we get back are fully functional/working cores, we don't take a core return on these. My mistake.
Thank you Jason,
Thank you!
