What Head Gasket with 383 Stroker
For the head gasket bore, this just needs to be bigger then your cylinder bore, and also bigger than your head combustion chamber width.
For the head gasket thickness, this needs to be optimized for the following:
1. Quench distance. Measure how far your cylinders come "out of the hole", then you will know what your quench will be.
2. Compression ratios: SCR and DCR. These will be influenced by your head gasket thickness.
3. PTV clearance. This should be checked, but generally speaking this should not be significant factor in the thickness selection. Gasket thickness ranges typically from 0.040" to 0.060", and if that has a meaningful impact on your PTV then you likely have other issues to sort out.
