MTI C2 cam VS. Comp 224 cam
Old Apr 26, 2004 | 10:07 PM
SS GIRL's Avatar
Default MTI C2 cam VS. Comp 224 cam
I am looking for a cam on a 112 lsa...
I am debating between the MTI C1 cam with the specs 224/224 .581/.581 112lsa and the Comp Cams 224/230 .580/.570 112lsa...
the MTI C2 cam I could buy brand new, or I can buy the Comp Cam used... can I get some feedback on these two...
and don't forget this would be my first cam so I am looking for kind of like a beginners cam... My b/f has a TR 230 on a 111lsa on his and he had a lot of trouble getting it tuned and I don't really want a lot of hassle... I will be getting tuning no matter what...
Old Apr 26, 2004 | 11:36 PM
SS GIRL's Avatar
is there any difference in the lope separations since one is made by Thunder Racing and one is made by MTI?
Old Apr 27, 2004 | 09:21 AM
SS GIRL's Avatar
ttt
Old Apr 27, 2004 | 09:39 AM
Cstraub's Avatar
SS,
Head Flow, Combination (ie bore, stroke, rod length, rocker ratio, compression) desired rpm range of power. Then the camshaft
Chris
Old Apr 27, 2004 | 10:04 AM
DenzSS's Avatar
Originally Posted by Cstraub
SS,
Chris
Ok..to help her out a bit.
Head flow:
Lift intake exhaust
.100 83 62
.200 134 104
.300 189 136
.400 222 165
.500 240 179
.600 252 185
Bore: 3.898"
Stroke: 3.622"
Rod Length: 6.098"
Compression ratio: Something close to 10.1:1
Rocker ratio. 1.7:1
Desired rpm range: 2500rpm - 6000rpm
Old Apr 27, 2004 | 10:27 AM
Cstraub's Avatar
Denzss,
About the same intake restriction we talked about yesterday?
Chris
Old Apr 27, 2004 | 10:28 AM
SS GIRL's Avatar
ok what????
Old Apr 27, 2004 | 10:29 AM
Cstraub's Avatar
SS,
Takes about 15minutes for this 386 Computer to warm up. . . .
Old Apr 27, 2004 | 10:37 AM
DenzSS's Avatar
Should be unless she's using a LS1 intake. Then add another 10-15 restriction.
Old Apr 27, 2004 | 10:45 AM
SS GIRL's Avatar
i will be using an LS1 intake....
the only mods I will have when getting the cam will be... headers, y-pipe (maybe a cutout), turndown, 3.73s, and lid...
or i get a custom cam from MTI, but i really wouldn't know which one would be the best for me...
Old Apr 27, 2004 | 10:46 AM
DenzSS's Avatar
Shoot me a PM if you want, I'll give you all of the options.
Old Apr 27, 2004 | 11:14 AM
JS's Avatar
JS
TR224 is the cam for that head...
Old Apr 27, 2004 | 11:18 AM
DenzSS's Avatar
Yup. TR224 or a custom. Either will do the job, custom will just do it a bit better. I'm a TR224 fan.
