which oil pump is better
Old Apr 26, 2004 | 11:14 PM
tedscamaro's Avatar
Default which oil pump is better
is there any different kind of oil pump besides the stock one that makes any difference when there is not a supercharger or a turbo on a engine that has just a cam, p/p heads , and boltons. i am rebuilding my engine that has 89k on it and im going ahead and putting a new oil pump for future safety
Old Apr 27, 2004 | 12:16 AM
onyxxtreme's Avatar
im pretty sure all you can get is either stock or modified-stock oilpumps
ive never seen anything else
Old Apr 27, 2004 | 01:27 AM
AmericanMuscle's Avatar
I've been running an LS6 ported oil pump for 15,000 miles so far, and I haven't had a problem.
Old Apr 27, 2004 | 08:54 AM
MYBLKSS's Avatar
Does the LS-6 pump run at a higher PSI?
Old Apr 27, 2004 | 09:01 AM
ataylors's Avatar
check with AP Engineering----->
Might still be able to get in on the GP they had going
Old Apr 27, 2004 | 09:07 PM
Ferocity02's Avatar
There are just stock and modified stock oil pumps. I got a ported LS6 pump from TSP and its great. Get's up to a healthy 80 psi at WOT. I don't think there is much of a difference between the ported LS6 pumps. There is the TSP, Katech, SLP, and one other. I just bought the cheapest.
Old Apr 27, 2004 | 10:57 PM
wrencher's Avatar
wrencher
Melling is making a new designed cast iron front case oil pump.
Haven't heard much about them though, they claim higher volume then stockers.
Old Apr 27, 2004 | 11:10 PM
Mike K.'s Avatar
Hmm that should be interesting.
Old Apr 28, 2004 | 05:04 AM
Deeavi's Avatar
You can always go dry sump, which is what I am going to do if I have anymore o-ring related problems!
