Engine overheating at idle?
Old Jun 14, 2013 | 11:10 PM
J-Rock1944's Avatar
Exclamation Engine overheating at idle?
I have a 1998 Z28 With an automatic transmission.
My car starts to overheat when idling or stuck in traffic, which is a bit of a problem since I'm selling it monday. It stays cool when moving, but once it stops moving, it starts to overheat.
Any help would be greatly appreciated, since I'm kinda on a schedule here to sell it. Thanks.
Old Jun 14, 2013 | 11:13 PM
LS6427's Avatar
Your fans are probably not coming on....or one is out. Or maybe they are not going into HIGH settings.
Next time you see the temp around 215 or more.......pull over and put your hand behind each fan....see if they are BOTH running. They should always run together, and run in LOW and HIGH together. Or OFF together.
Check the relays if they aren't running.
Fans are the only thing that keeps the engine cool at slow speeds or in traffic, or idling.
Old Jun 15, 2013 | 08:40 PM
J-Rock1944's Avatar
I let my girlfriend drive it too work, she brought it back at the stock running temp. I let it run until the fans SHOULD have come on.... they didn't.
Any idea as to how that is fixed?
Old Jun 16, 2013 | 08:07 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Exactly what LS6 said. If it's ONLY happening at idle then the fans aren't working.
Check the fan fuses to ensure they're not blown, and just go ahead and replace the rely. I'd highly doubt its a wire issure. Never hurts though to poke your head under there and ensure the wire didn't pull out from the plug.
Old Jun 16, 2013 | 12:43 PM
J-Rock1944's Avatar
Checked the fuse for it under the hood (40 large type.) and it has black...something on the inside running across the connector prongs. The relays all looked good, no visible burn marks. Not exactly sure HOW to test the relays, but outward appearances seem good.
Anybody have an idea how to test the relays?
Old Jun 17, 2013 | 04:53 PM
LS6427's Avatar
Just pop the other relays out and pop them in the fan positions to see if the fans come on........but it's got to be up to temp or......I think the A/C can be turned to MAX and the fans should come on always. Not sure though.
Old Jun 17, 2013 | 05:02 PM
Red89GTA's Avatar
Yep, a/c on will kick on the fans. any car will be set up that way.
Old Jun 17, 2013 | 05:10 PM
Zlow28's Avatar
Bleed your coolant like 3 times to make sure you have no bubbles in there. My lt1 had the same problem.
Old Jun 17, 2013 | 07:28 PM
J-Rock1944's Avatar
I found some spare relays from my TA before it was totaled by some stoner kid, and fixed the problem. Now the car is in the hands of young kid with a level head and a love for Camaros.
Thanks for the help guys, I'll be sure to pass the knowledge along too him.
