236/236 .590/.590 112 help
Old Jun 17, 2013 | 11:05 AM
Palomows6's Avatar
Default 236/236 .590/.590 112 help
Will this cam require flycutting? I have stock 241 heads. Any opinions on this cam ? Thanks
Old Jun 17, 2013 | 11:30 AM
PREDATOR-Z's Avatar
On paper it shouldn't. What is the advance in the grind?
It has a bit of a late IVC for stock compression to my taste (even at 108 ICL). With proper intake it should make healthy power mid to upper rpms.
Old Jun 17, 2013 | 07:20 PM
Palomows6's Avatar
[QUOTE=PREDATOR-Z;17481432]On paper it shouldn't. What is the advance in the grind?
It has a bit of a late IVC for stock compression to my taste (even at 108 ICL). With proper intake it should make healthy power mid to upper rpms.[/QUOTE
No timing advance. You think some 5.3 stage 2.5 heads work better? Ive been looking at texas speed for some heads.
Old Jun 18, 2013 | 12:03 AM
PREDATOR-Z's Avatar
It is on a 112+0 LSA?
Then no, not good valve events for 346 cids.
Old Jun 18, 2013 | 01:04 AM
JakeFusion's Avatar
Super Hulk Smash
That'd be a good cam for a 383...
Old Jun 19, 2013 | 02:00 PM
SNLPerformance's Avatar
[QUOTE=Palomows6;17482455]
That would be pretty tight PTV with 5.3 heads depending on valve size, milling and gasket thickness...would definitely check it.
