Engine developed rattle/ticking noise, what could it be? Does it sound expensive? :(
#63
Anyway at this moment I've gone the route of "remove intake/valley cover" to try to check lifters
Already took me 3 evenings with all the cleaning and yesterday I stopped because I couldn't remove allen valley cover bolt (passenger side rearmost). Don't know why other 9 bolts are normal 10mm and this one is 5mm inner head...
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#65
You are going to have to pull the heads, no way avoiding it. I had a slight tick sound that got louder as well, no barking sound though!!
Here is the thread with plenty of pics:
https://ls1tech.com/forums/generatio...-breakage.html
#70
I know where bearings are, I asked how to check them without removing rod caps ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I didn't remove caps today BUT I've found that cam is scored on the "middle" lobes of cylinder 3 and 4, and lifter rollers don't look pretty either![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
But I guess, since I'm there already, I should still visually check rod bearings?
#71
That's going to be tough without taking the rods out since they are connected to the crank. You could try to rotate the assembly and see if you hear any noise but I'm figuring that the noise you heard was the cam and lifters. If you want to be thorough, take the motor completely apart to give yourself piece of mind.
#74
OK whoever is willing to offer his educated advice, here's the latest info.
Rod bearing (checked 2 of 8) are worn but fine. Crank rod journals (2 of 8) are fine.
2 lobes are eaten about .05" by the feel, unfortunately on different sides so both heads will have to be removed.
If I take the engine out, I have to order:
-head gaskets (LS9 I think)
-lifters
-lifter trays
-exhaust gaskets
-cam
Am I missing something?
edit: by the looks of it, I will have to race this engine with bad lifters once again... I just hope metal debris from lifters/cam will not flow into crank bearings...
-lifters
-lifter trays
-exhaust gaskets
-cam
#75
Stop racing
Seriously if the lifters fall apart there will be a lot more damage!! You will also need intake manifold gaskets, head bolts, header bolts, oil pump, MLS head gaskets (better than that graphite crap which will be a pain to clean off). That's all I can think of for the moment. I had posted a thread https://ls1tech.com/forums/generatio...-breakage.html, has pics and can pretty much give you an idea of how the repair is going to go.
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
#77
Dude, you are nuttier than squirrel poop if you race a motor in that condition. Right now you need a cam and lifters. After your race you are going to need a full rebuild and probably bushings in the lifter bores...expensive work. Might as well buy a new long block. If youve got the money thats cool I guess, it just makes no sense at all to a guy like me.
