Long term block storage
Old Jun 30, 2013 | 07:09 PM
KilerTA's Avatar
Default Long term block storage
I recently picked up a LQ9 block. What is the best way to store/preserve the block/cly walls from rust ect ect.
Old Jun 30, 2013 | 07:29 PM
Darkman's Avatar
If it is not rusty now, and will be stored in a relatively safe envirionment you can simply coat the surfaces with motor oil and wrap it in a sheet of plastic.
If it will stored in a high moisture environment for an extended time period, I would look at some cosmoline products.
Old Jun 30, 2013 | 07:32 PM
KilerTA's Avatar
I was thinking or rubbing down the Cly walls with Wd-40 and wraping in a plastic bag. It just dawned on me i can get a hold a ton of desicant i could toss in the bag to "wic" moistre
Old Jun 30, 2013 | 07:42 PM
Darkman's Avatar
WD-40 is okay for short time periods. In a spray product that similar but longer lasting I would look for some LPS 3. Additionally, I think Rustoleum and 3M offer some higher viscosity WD-40 alternatives that will give longer protection.
Old Jun 30, 2013 | 07:44 PM
sreve's Avatar
If you use cosmoline it's a done deal no rust. Aerosol cans $10 - 15
bucks cheap insurance.
Old Jun 30, 2013 | 08:22 PM
KilerTA's Avatar
Is this something that the local auto parts store would have?
Old Jun 30, 2013 | 10:55 PM
baronsmith98's Avatar
How long are you storing it? Id only use cosmoline if it was being stored really long. Cosmoline is a bitch to clean i use it a lot at work
Old Jul 1, 2013 | 06:29 AM
Busted Knuckles's Avatar
Try to find a place that sells Mystic oil products. They have aerosol cans of spray grease. One can will cover all 8 cylinder walls, deck, mains and bearings. Be nice to your builder, though, and find a car wash with hot water and wash it good before you take it to him, grease (including Cosmoline) are tough to get off even in a block washer.
Forget WD-40, it won't last a month. You need something with stick.
Old Jul 1, 2013 | 07:38 AM
PREDATOR-Z's Avatar
Vacuum seal it.
Old Jul 1, 2013 | 04:41 PM
vettenuts's Avatar
Yep, they make engine block storage bags. I would coat it, bag it and put some desiccant in there as well to keep it dry.
Old Jul 1, 2013 | 05:36 PM
SS67SS's Avatar
I've stored many cylinders (bare metal machine parts) with CRC HDCI. Wrap them in a zip-tied garbage bag and forget it.
Go to any marine supply store and they will have many similar options.
Old Jul 1, 2013 | 05:44 PM
sreve's Avatar
http://www.steelerectortools.com/cat...66/6234586.htm
Old Jul 2, 2013 | 06:41 AM
Drop 'er in a barrel of used oil and put the lid on. It'll be fine in 1000 years.
I actually have a buddy that has a DZ302 block stored this way.
