5.3 na builds
Old Jul 9, 2013 | 09:46 PM
LS1BADZ's Avatar
Default 5.3 na builds
Anyone have some strong na 5.3 combos?
Old Jul 10, 2013 | 06:08 AM
TheWolfMatt's Avatar
Do a search for it and I'm sure you'll come up with several builds to your liking.
Old Jul 10, 2013 | 10:26 AM
LS1BADZ's Avatar
I did and most were Weak sauce
Old Jul 10, 2013 | 04:33 PM
redtan's Avatar
That's cuz it's a small bore motor with limited choices for heads. And even decent heads like 799s have their valves shrouded by the small bore.
Old Jul 10, 2013 | 05:58 PM
wildcamaro's Avatar
Yea best thing to do on a 5.3 is follow the L33s design of flat tops for high compression with good 243/799/aftermarket heads...when you have small cubes you need rpm to make big power if NA...do a google search on the test where hot rod magazine got junkyard 4.8 and 5.3 and made mid 400s hp on the engine dyno by using ported/aftermarket heads with a fast top intake and bigger injectors...very impressive test!
Old Jul 10, 2013 | 05:59 PM
Cwarta's Avatar
My 99' 5.3 is going to be N/A shooting for 460+ rwhp
Old Jul 10, 2013 | 06:32 PM
wildcamaro's Avatar
If keeping stock cubes you would almost have to spin it up to 7000+ rpms to keep that kind of wheel hp bc that's 600 crank hp you're talking about...not saying it can't be done but more than likely would be a first...def have to be well engineered package that's for sure
Old Jul 10, 2013 | 07:32 PM
Cwarta's Avatar
Oh it's bored .220 and gunna spin 7,000+
Old Jul 10, 2013 | 08:22 PM
garygnu's Avatar
Martin at Tick has been doing cams for 5.3 .
Old Jul 10, 2013 | 10:12 PM
wildcamaro's Avatar
So not a 5.3 it's a 6.0 lol entirely different story
