There are 2 kinds of YT rockers
Does the heel of the updated rocker clear the valve cover? Asking because I have Lunati shaft rockers that look a lot like the updated YT's and they do not fit without rail spacer and mod's to the spacer itself.
They do clear. They are VERY close to the AFR heads at the valve cover rail, but don't touch.
That would not have made me happy........
The Lunatis will be good when you get them to fit, they make excellent products.
Any photos?
Miami, I have them cleaned and at work, I'll have a look see sometime this week. We have some microscopes that cost way more than my car......
Ron
Any photos?
Ron
I installed YT Ultralite's on my TFS 215 heads back in March 2009. The heads come with 450 open PSI springs, and I used 7.5 Comp 5/16" pushrods. Also had the G5X3 114 XER cam. I always used Mobile 1 15W-50 oil, and use a 160* stat to keep the engine temps down.
In October 2011, #5 piston let go destroying the block. So I installed a TSP 418 strocker & reused the cam and heads. Last year I installed an EPS 234/242/.600/.615 117+2 cam. Also installed the BTR Platinum valve springs that have ~50psi LESS open pressure. So I'm sure that I'll never break a rocker arm.
What open spring pressures are used that's causing the rocker failures? YT also makes a Platinum series rocker for extreme valve spring loads.
Russ Kemp
Russ Kemp
I installed YT Ultralite's on my TFS 215 heads back in March 2009. The heads come with 450 open PSI springs, and I used 7.5 Comp 5/16" pushrods. Also had the G5X3 114 XER cam. I always used Mobile 1 15W-50 oil, and use a 160* stat to keep the engine temps down. In October 2011, #5 piston let go destroying the block. So I installed a TSP 418 strocker & reused the cam and heads. Last year I installed an EPS 234/242/.600/.615 117+2 cam. Also installed the BTR Platinum valve springs that have ~50psi LESS open pressure. So I'm sure that I'll never break a rocker arm. What open spring pressures are used that's causing the rocker failures? YT also makes a Platinum series rocker for extreme valve spring loads. Russ Kemp
My car pulls hard to the 7100 RPM fuel shut off without missing a beat.
Russ Kemp
