5.7 or 6.0
Old Jul 15, 2013 | 12:02 PM
98z8uup's Avatar
Originally Posted by JakeFusion™
You're in a vette tho? Not a wallowing F-Body boat car.
I don't think he was in the vette when had too make the choice.
Old Jul 15, 2013 | 01:32 PM
chevybayboy's Avatar
Yea I blew.my bottom end so I was looking into short blocks.. 110# is a lot of extra weight in the front , and I don't want to redo the suspension and all that, and I'm not going FI just a little 100-150 shot of juice with some forged pistons... I think I'll stay aluminum.. now my question is would it be cheaper to rebuild my block or just buy a short block?
Old Jul 15, 2013 | 02:28 PM
Roarin_8's Avatar
Buy a short block
Old Jul 15, 2013 | 02:29 PM
lemons12's Avatar
I'd call Thompson.
Old Jul 15, 2013 | 02:30 PM
JakeFusion's Avatar
Super Hulk Smash
I've been impressed in talking to Kyle. Thompson seems like a legit way to go.
Lemons, do you notice much adverse affects to handling with the iron block in there?
Old Jul 15, 2013 | 02:45 PM
lemons12's Avatar
His customer service and warranty (especially warranty) are not matched by any that I have ever encountered in all my dealings on ls1tech. He goes the extra 3 miles!!
Well... The Pewter car had skinnies the entire time and it had been well over a year since I had drove it with the aluminum block. No front sway bar the entire time. It didn't handle worth a damn but I attribute most of that to the skinnies.
The red car had the front sway bar when I got it on a 275 tire, 245 now. I removed the front sway about 2 weeks ago.. I noticed that a little but nothing crazy.
I don't notice my iron block car handling any different than my GFs stock 00 Z28. I have Qa1s also.
If it does make an impact it isn't one that is too serious. I guess someone who loves cornering would notice. I like to be able to take corners but I don't get serious with it at all, just some spirited driving here and there.
Old Jul 15, 2013 | 02:56 PM
thunderstruck507's Avatar
I think folks use the 6L block and use it as a cheap way to put together a **** poor combo.
Could be.
But if you look at lq4 or lq9 threads in the dyno and racing sections of this site the results are generally the same as average ls1 stuff but some extra ft lbs of torque.
I've seen multiple threads where users were asking why their car was slower or barely faster with a new 6l combo than it was with a prior ls1 combo.
You might be correct that it is a case of people taking the build for granted and assuming more cubes is going to equal significantly more HP. Torque sure, but rwhp increases seem to disappoint.
Old Jul 15, 2013 | 03:00 PM
lemons12's Avatar
It is 18? more cubes.. That is nothing hardly.
The added benefit comes from being able to optimize the setup with a nicer set of heads... Most people don't take advantage of this so never see the potential a 6.0 has over a 5.7.
I wouldn't run the same heads on a 6.0 as I was a 5.7 unless $ didn't allow any different.
Old Jul 15, 2013 | 03:13 PM
JakeFusion's Avatar
Super Hulk Smash
I talked to Brian Tooley about the heads I have, and he wants to optimize them for a 4" bore. That's where the power comes from - optimizing for the setup.
Old Jul 15, 2013 | 03:23 PM
lemons12's Avatar
Boom.. 5.7, 5.3, 6.0... Everything has to be optimized.
Old Jul 15, 2013 | 03:32 PM
intenseblue's Avatar
It is cheaper to build what you have. A new shortblock will be more expensive than rebuilding your current block.
Old Jul 15, 2013 | 04:03 PM
  #32
Yea I just got off the phone with G&G pretty good prices I think I can save about 700 just to have them rebuild it with what I want as well.Thanks for all the info everyone I know for sure what I'm doing now
Old Jul 15, 2013 | 04:05 PM
  #33
Maybe, maybe not depending on parts selection, machining costs in the area, if there is a core program, if you are paying someone for assembly or need tools, etc.
Some of the sponsors selling shortblocks are doing so with warranties for some hard to beat prices.
Old Jul 15, 2013 | 05:23 PM
  #34
Yea I see sine good prices @ Thompson's total would be about 2500 for short block with forged pistons, G&G said for the cleaning honing and decking with cam bearings installed 450 I'll get some forged Pistons 500 and reuse my rods and get arp rod bolts with labor and everything should be about 1700-1800
Old Jul 15, 2013 | 06:36 PM
  #35
kylemm1002's Avatar
I'm going through the same thing right now. I was originally building a 2005 lq4 motor for my car but my camaro has a good ls1 in it. Was going to put some ported 243s ls6 intake and a tick cam into the lq4 because of the better rods and bolts. But now I'm thinking about just building the ls1, in just worried about the ls1 rod bolts spinning to 6600.
Old Jul 15, 2013 | 06:42 PM
  #36
JakeFusion's Avatar
Super Hulk Smash
1700-1800 includes the balancing of the rotating assembly? Usually that's about $200 or so.
Old Jul 15, 2013 | 07:13 PM
  #37
Yea I couldn't figure it out Lol I think I'm going to stay aluminum
Old Jul 15, 2013 | 07:17 PM
  #38
I didn't add that into the equation.. so I'm guessing 1900-2000 I'm going to order the phobe forged pistons there 500$ plus the decking and, cleaning and can bearing 450.. 75 a hour to reassembling I think it was 3-4 hours? Balancing the crank 200 am I missing anything?
Old Jul 16, 2013 | 04:27 AM
  #39
lemons12's Avatar
The big saving is doing the assembly of the short block yourself.
If I wasn't going to do that, I would buy from Thompson.
Old Jul 16, 2013 | 01:54 PM
  #40
I was going to break it down myself, and have the shop reassemble it, the cost for the motor I'm looking at, at tsp is 2200 +300 shipping so 2500, it wouldn't be cheaper to have the shop"reputable " shop do it to balance the crank and hone deck new cam bearing for 450 I'm going to buy the forged pistons there for 500 I'm looking at around 1700$ is that right? If so I'd rather go that route and out the other 700 in nitrous
