No oil pressure
Old 07-27-2013, 08:15 PM
ridndirty1000's Avatar
Default No oil pressure
I did a cam swap and replaced springs cam timing chain and oil pump and when I got the car together it started right up but no oil pressure I put a hubbard ported ls6 pump on it and new rubber o ring. PLEASE ADVISE
Old 07-27-2013, 10:01 PM
GmansZ's Avatar
I would check out sending unit first, very easy to break.
Old 07-27-2013, 10:09 PM
ronsws6's Avatar
I agree. I bet you broke the sending unit.
Old 07-28-2013, 06:26 AM
I didnt even touch the sending unit. Your talking on the back of the block correct.
Old 07-28-2013, 06:33 AM
do you think it could be that the o ring got pinched in between pump and pickup tube?
Old 07-28-2013, 07:07 AM
Old Geezer's Avatar
Talking Yes....
And, are you SURE you used the correct o'ring?
Old 07-28-2013, 07:26 AM
Well I bought a new one for it and I matched the size up but the new one was thicker then the old one.
Quick Reply: No oil pressure
