Built new 383 and Got Blowby
https://ls1tech.com/forums/11059703-post70.html
However, this is not the reason that you are getting blow-by. When I first built my engine, I made the same mistake and set up the PCV backwards. I ran it that way for a few weeks and didn't get any blow-by.
What do the plugs look like?
Other items to consider:
Ring broken on install.
Rings on upside down.
Insufficient ring end gap.
Oil ring rail not on correctly. [Overlapped?]
Incorrect wall hone finish.
Excessive piston to wall clearance.
Just to expand on Old Geezer's ideas, people often MISTAKE "built" for built well, that is not the case. Most reputable local shops aren't even that good if you then take the engine to someone who really knows what they are doing.
Point being keep an open mind when looking for the problem, I have seen too many guys have too much faith in vendors they trust and refuse to see shoddy workmanship.
http://www.youtube.com/watch?v=QXm9c...ature=youtu.be
hi Old geezer,
tomorrow i will take to the shop to start checking the things you are asking,the bad thing is that the oil smoke is burning somewhere and start leaking from behind the engine,maybe in the crankshaft seal or what else can be from behind?
thanks for your help geezer
You REALLY need to do a compression and more importantly leak down test. That is a TON of blow by. Get that motor checked out.
After the tests, if you didn't build it yourself you need to go back to the builder. Assuming there aren't too many miles on it.
Edit: with only 200 miles I'd suggest talking to the builder.
hi,,i was thinking about the same,i think the excess pressure is making the seal leak ,the oil is not Mobil 1 ,is a Regular Mobil Super 7500 Mineral Oil,i was thinking put Mobil 1 before 1000 miles.
thanks!
