.005 hone with stock pistons
I am trying to price my rebuild with diffrent options. Can I opt to reuse the stock 3.898 pistons if I hone the cylinder walls .005" ? If so can I use a set of 3.903" rings on the stock 3.898" pistons ? Help a noob out
I understand where your coming from. I was watching a pretty good ls1 rebuild series on Youtube by "MrWhiteLS". He reuses the stock pistons and rods after using a stone hone on the cylinder walls. He dosent specify what size rings he goes with. I guess he went with a VERY minimal hone with standard .00 rings.
-Phil
The only caveat to buying new is you should have your rotating assembly re-balanced, which is usually part of a decent re-build anyway.
