How would this cam perform in this set up?
I never heard if spec u cam. I may have to check they're site out. Everyone refers me to Martin at tick, I talked to him and he seemed really knowledgable. It was just rather late when I found this numbers and they were no longer open. I was just gonna check the pulse if the people while I was at least feeling like I somewhat know what I'm doing
I said 231/238 112+2 on the LSL/LXL lobes.
If you want more torque, you can go a little smaller on the duration and tighten up the LSA/ICL like the Tick SNS Stg 2: 227/234 110+3. But since it's a 6L, I'd probably go a little bigger and do the following:
If you don't have money to port the heads but can mill them for ~$80 to 61cc and run .040" cometics, I'd do the 231/238 112+2. Even with 12.1:1 CR, you'd have good cranking compression, something that drives decently with ~10 degrees of overlap and something that makes power and torque. Everywhere.
(I thought to put on the right track).
Pred I have heard you know your your performance stuff. I have seen you mentioned in more than a few threads. I'm really gonna give them a jingle now. Thanks!!
Has a nice torque curve and will run well at the track too.
I am probably going be calling you tomorrow to set up my order. I dont need the ported oil pump but everything else in ur kit is really going to complete my build, what time do you guys open in the am and what all gaskets come in your kits again?
1- Checking springs once a year (regardless of how much it ran)
2- Replace springs as required.
springs do not have an expiration time/mileage or date. It all depends on individual setups, some might last longer than others but keeping a serious eye on them is considered regular maintenance just like changing oil.
So even going with a milder cam won't improve spring life, dang that sucks. How do you check the cam springs anyway? Thanks pred z this is great info.
Usually you check the spring pressures at a machine shop who has the tools.
I bring them all the springs, they measure and I get the report. If one is bad or on the edge, ALL get changed.
