58x truck with 24x motor. Best way to change it over?
Should I use the lingenfelter or could I just use a engine harness from a 24x truck?
It's a 24x 402 stroker trying to get it into a 2008 short wide which was the 58x reluctor.
I'm sure someone knows what is best way to do it. Thanks
The difference is not in the harness. It is hard coded into the computer. I would skip the trouble and have a machine shop swap the right wheel on the crank.
