Gen III/IV hybrid...LQ4 block, LS7 crank, TI rods, 24x
So I want to make sure I'm not missing anything...
Now why I'm doing what I'm doing...I have the LQ4 block, LS7 crank, full set of LS7 titanium rods.
As far as 24x conversion...I have 2 junk 24x cranks, plenty of Gen III covers, no Gen IV's, have Gen III cam sensor, and MSD 6LS is slightly cheaper (about a wash with reluctor swap charge) for Gen III.
So now I can run a spacer or cut snout. Why one over other or does it make a difference?
I will be going with a custom made piston to the LS7 specs other than bore size.
This will most likely go into a Fox Mustang with Vic Jr. or possibly sell if I can make a buck.
I have no information for you, but I am sure interested in this build... New to the GM world, so maybe people do this all the time - but I haven't seen it yet.
What displacement will this result in?
What bore size are you going with?
What heads are you going to run?
![Popcorn](https://ls1tech.com/forums/images/smilies/popcorn.gif)
Block is being Sonic tested right now to figure out max safe bore. Most LQ4/LQ9's can got .080" for N/A applications. If that's the case I will go .070" for 4.070" bore and 4" stroke. 416 CI...
In the rare event that I can possibly go all the way to .125" I can run the stock LS7 pistons! Probably not likely...
Not sure on heads yet. Probably just GM CNC LS3 heads. $1200/pr
I just got $660 for tank and pan after shipping, $80 for cam, and using lifters in my budget 5.3 build.
So realistically I'm in the crack and rods (plus valley cover with pcv) for like $210. (Putting a used value of $50 on lifters). And I'll still have some misc pieces.
Jason
Super Hulk Smash
I'd definitely use the rods and crank. The crank can be machined to fit the LQ4.
I'd look at some custom Wiseco pistons tho to fit the LS7 rods and 4" crank for whatever bore you end up with on the LQ4. Figure out your heads now so when you order, Wiseco can put the correct valve pockets in the pistons...
I may just do CNC LS3 heads budget wise. $1200/pr is already more than my shortblock lol
I think I got your pistons for you!! Assuming your going to do the smart thing and go with a 4.030" bore, my math shows that you need a piston with a compression height of 1.183" using a 4" stroke and the 6.067" length rod. With a .925" pin. Check these pistons:
http://www.ebay.com/itm/Wiseco-ProTru-FORD-327-Forged-Pistons-set-4-030-5cc-WISPT070H3-1-1755-CH-/380688153686?pt=Motors_Car_Truck_Parts_Accessories&hash=item58a2c83c56&vxp=mtr
You will have to probably flycut valve clearance and deck the block a mere .007" to get zero deck height.
The original LS7 Piston compression hight is 1.173"
1.173" (LS7 Piston C.H.) + 6.067" (LS7 Connecting Rod) + 2" (LS7 Stroke /2) = 9.24" Block Hight.
Those are .0025" taller. So assuming the above is correct and the LS7 has zero out/in hole then these would put me at .0025" out of hole assumes perfect 9.240" deck height. Hmm
Great find!!
What is the pin offset on the ford pistons?
Also, the valve reliefs will be on the wrong sides of the piston as ford starts with valve arrangement opposite of GM. Ford starts with the intake valve leading on the front of the bank as opposed to the exhaust like GM.
and the placement of the valve reliefs. IMO, it would be easier to find a piston to fit the bore and whatever heads you're using (LS3 or cathedral) and have them put a custom CD on it with the correct wrist pin.
Also, I believe the Ford engines have a different valve angle as well, which would further complicate the valve relief issue.
