Cam ??
Old Jul 9, 2013 | 10:51 PM
acechevy's Avatar
Default Cam ??
I have a 98 camaro auto trans 3:73 gear is what im looking to install. Its a stock bottom end lq9 other than arp bolts with milled ported and polished 243 heads. I have long tubes off rd y pipe. Needing a stall also not sure what would be a good size or brand car is a daily driver also. Any other mods would be helpful thanks ace
Old Jul 10, 2013 | 11:09 PM
acechevy's Avatar
not sure this is in the right spot or if my phone is posting anything but posted several posts and havent gotten any replies lol
Old Jul 11, 2013 | 01:07 AM
99Bluz28's Avatar
I consider looking into getting a higher stall TC before getting a cam. The stall size will be somewhat depend on the cam size. What rpm range do you want the most power in, do you want a smooth or lumpy ide?
http://www.circledspecialties.com/
http://www.converter.cc/
Old Jul 11, 2013 | 07:28 AM
acechevy's Avatar
Getting a stall also for my 4l65e that im having built i want a choppy cam around a 110 lsa run its driven daily and take trips to car show with so driveablity i am going to need the cam that is in there from when.i had it.in my truck is a isky 216/218 on a 112lsa sounded good in the truck but digured i could make more power than that.
Old Jul 11, 2013 | 07:34 AM
mark21742's Avatar
Gm asa cam? It has a low lift so your valvesprings will last forever if you get a good set...or if you want to go bigger than that maybe a 228/234 <.600 lift (for valvespring life) and a 110-111 lsa with a 3, 600 stall
Old Jul 11, 2013 | 10:17 PM
acechevy's Avatar
I want to turn the most i can out of it but keep it driveable i have my truck i drive every day but do drive the car few days out the month and to shows etc
Old Jul 12, 2013 | 12:18 PM
2000PewterT/A's Avatar
3600 stall, 228r is a good daily driver combo that has been done many times before so you can search different setups and see if that's what you are looking for.
Old Jul 12, 2013 | 10:50 PM
acechevy's Avatar
Ok thanks ill check into that
Old Jul 14, 2013 | 12:51 AM
acechevy's Avatar
I seen alot of sound clips thay cam sounds mean. But i didnt seen any dyno sheets or know around the power range i could make with yhat set of
Old Jul 14, 2013 | 09:48 AM
HCI2000SS's Avatar
Well two things to remember...a larger cam will behave a little better in that LQ9 compared to a LS1, and a great tune will make a huge difference as well! I am about to do a LQ9 myself here, but i'll be running my PRC 5.3 heads on a 6-speed with 4.10's, but am getting a cam in the mid 240's duration...not worried about low end power issues or drivability. Do you know what your compression is at? That makes a difference as well
Old Jul 14, 2013 | 11:47 AM
acechevy's Avatar
Yea i really want to six speed my car but everyone wants a arm abd leg gor trans i found one for 300 but the guy draggin his feet. By what i was told the 243truck head milled like the are it should be around 11:1 compression
Old Jul 31, 2013 | 06:50 PM
acechevy's Avatar
Does any one have a sales man that is good to deal with I've done emailed tsp and eps about cams and I've not hot anything back. Thanks
Old Jul 31, 2013 | 07:07 PM
Blackpanther99's Avatar
Call them. Those guys get tons of emails a day. Lol
Old Aug 1, 2013 | 06:35 AM
mark21742's Avatar
Call and send them a message on here in pm
Old Aug 10, 2013 | 09:31 AM
acechevy's Avatar
Ok thanks
