Valve train issue
Old Aug 15, 2013 | 10:15 AM
HeavyGlock's Avatar
Default Valve train issue
Ok I have a 98 camaro has a 383 stroker. It hesitates badly in low rpm then somewhat clears up in high rpm. Seemed like a vacuum leak or ignition. I have tried over and over to find a vacuum leak and replaced everything but the coil packs. It doesn't throw codes. My valve train seems noisy which I know some do. But I was gonna check it out anyway just to be sure. My main question is can something in the valve train going wrong cause those symptoms. It has a ms3 cam and roller rockers. The previous owner didnt know anything else about it so the rest could be stock or could be good parts. Another reason I'd like to look. Just looking for any ideas to look for or go after. Thanks guys.
Old Aug 15, 2013 | 10:36 AM
wildcamaro's Avatar
I'd pop the valve covers and visually check the rockers to make sure everything is kosher...usually a bad coil will throw an engine code
Old Aug 15, 2013 | 05:33 PM
HeavyGlock's Avatar
That's what I was thinking. I might try to pop a plug wire off and make sure it throws a code. Just to make sure. Though other then something obviously broke or loose I'm not sure what I'm looking for under the valve covers.
