Rectangular Ported 241's!!!
Old Aug 18, 2013 | 04:51 PM
Justhereforinfo's Avatar
Can you post a pic of the combustion chamber side?
Old Aug 18, 2013 | 11:49 PM
xRaTeD's Avatar
Just looks like a crappy job that somebody sandblasted to cover it up and make it smoother.. But hey if it works it works.. You obviously praise the motor and it seems to have put up numbers your happy with then why ask about it... They don't look fancy bet they are better the stock so that's cool..
Old Aug 19, 2013 | 03:42 AM
vettenuts's Avatar
I would be concerned with rocker stand fatigue and break through. It has happened to many porters in the past. There have also been cases of cracking due to thin walls that lead to big oil consumption. Not sure if these are issues in this case, but it might bear more research.
Old Aug 19, 2013 | 03:46 AM
Exidous's Avatar
It would probably work well with a screw type charger. If only a TVS 2.3 would fit. :-)
Old Aug 19, 2013 | 07:32 AM
2000ultraZ1911's Avatar
Those are pretty wild lol. Like he said if they wrk they wrk. Love the notch!
Old Aug 19, 2013 | 07:54 AM
texas94z's Avatar
I'm very curious to see what the flow bench says. Lots of props for trying some creative.
Old Aug 19, 2013 | 08:23 AM
badazz81z28's Avatar
Originally Posted by McCain_Racing
As the other guy said..they came off of a running motor and a damn good one at 3700 pounds. So the not running them is out the door, I have plenty of knowledge about these ls motor, sbc's, sbf's, bbf's, and bbc's, I wasn't brought into the racing game yesterday. Me and my brother owned one the fastest stock bottom end ls1's on the planet till this day and plan on bringin another beast back out!
Best e.t. with our mustang @ 3260 race weight:
60ft- 1.25
1/8th- 5.80 @ 118
1/4- 9.50 letting out of it
This is the 5.80 pass
Ryan's Ls1 Stang Test Pass - YouTube
Ok....Just because you can hog out a pair of LS heads and run them down the strip doesn't make them reliable. MOST of the members here look for a pair of heads they can slap on their LS and drive it around on the street and the track for many thousand miles. If your goal is to just get down the strip a few times and not worry about tearing the motor down every season than these are for you. As mentioned, the LS heads are not special, you can't make the ports paper thin and expect them not to have possible issues. Like mentioned, the rocker bolts pass right through the intake ports.
Hey, what ever works for you. Your project does make power, but that's about it. If you have been in the racing game for this long, you know that BBC heads were heavily welded to hog out the ports, because they will crack. I have seen the same issues with LS heads. Would you like to see the threads?
But yes, congrats on making your goal with the less desired 241s.
Old Aug 21, 2013 | 03:04 PM
McCain_Racing's Avatar
To anyone and I who wonder of "tf" did these heads, The recent owner said some NASCAR shop did them?
Old Aug 21, 2013 | 06:33 PM
garygnu's Avatar
what intake are you using ?I to would be worried about the rocker arm stand breaking.how close are the coolant passages ?
Old Aug 21, 2013 | 11:48 PM
01ssreda4's Avatar
Hogging a cathedral port doesn't make it a rectangular port. I'd throw em in the trash personally.
Old Aug 22, 2013 | 12:15 AM
studderin's Avatar
dang, I didn't know making the injector notch squared off, made for more power.
I'll have to try that!!!!
Old Aug 22, 2013 | 03:23 PM
  #32
Lmao I think he planned on a more positive response then he got.
And that camaro vid could just be some random and shows no time lol
