replacing 228r
Old Aug 25, 2013 | 10:28 PM
dannyz's Avatar
Originally Posted by Apocolipse
Why do most use 114?
Easy idle plus tune
Old Aug 25, 2013 | 11:56 PM
Redbull87's Avatar
Im quite happy with my 228r.With the cam choices mentioned so far..the differences you will see are going to be mainly in power curve,driveability(good tune will make them equal),and valvetrain wear/tear.Power wise I see some trading +/- peak numbers from 10-20hp/tq.
A good combo of head/cam will perform better than a bigger cam that doesnt like the rest of the motor around it.That is 1 thing we will all agree on.Can you go bigger cam..sure,is it necessary..probably not.
When my lq4 was just cam only on the stock 317 heads.I didnt like it..I wanted more and my thought process at that time was..damn I shouldve gone bigger cam!I simply changed heads to 243's and had them milled and it made a world of a difference especially on the dyno still on stock manifolds I got lots more to improve on.Drives nice..great all around power band on 112lsa and idles nice at 800rpm.Am I worried about valvetrain with this cam..nope.To me..its something that us lsx guys should be looking at regularly regardless if your hard on the motor or not since its not our strong points.Try the cam..you might just be happy with it having those heads it will be responsive..couple with good flowing intake/exhaust the cam will perform.Its made many very happy for many yrs and still is.
Old Aug 26, 2013 | 09:10 AM
Apocolipse's Avatar
Seems to be that way too many people are going too big and ending up with useless power up in the 6-7k region. I want something that brings the power on down low, and just change gears!
Old Aug 26, 2013 | 09:28 AM
thunderstruck507's Avatar
mine is a 230/238 113+2 peaking at 6200rpm but carries nearly flat until my 6700rpm limiter
has more torque down low than it did with stock shaved heads and a tiny 230/224 XE lobed cam
Old Aug 26, 2013 | 10:07 AM
bpopham22's Avatar
Yeah I'm pretty sure I'm going to keep it. I'm saving for a fast 92 combo right now.
Old Aug 26, 2013 | 10:22 AM
Apocolipse's Avatar
Street sweeper is 228/232 -111 @ .612"-.600"
Seems like a pretty good combo with ported heads and increased compression.
I will not be spinning it higher than 6500 so I want more power down low. Useless up high (for me).
Old Sep 15, 2013 | 02:32 PM
Slimsilverado's Avatar
Let me know if you want to sell the 228r
Old Sep 16, 2013 | 01:49 PM
bpopham22's Avatar
Ill be keeping the 228r hopefully getting everything installed in mid October. Still debating on a fast 92 combo
Old Sep 16, 2013 | 04:23 PM
MikeWS6's Avatar
Or you could pass in the fast and put that 2500 towards a procharger
Old Sep 16, 2013 | 08:04 PM
bpopham22's Avatar
Yeah I would love a procharger,but with 100k on the motor I would be better off going with a forged shortblock first
Old Sep 17, 2013 | 08:42 AM
If someone is finding a way to spend $2500 on a FAST 92 they are ******* retarded or don't shop around for ****.
Old Sep 17, 2013 | 02:48 PM
  #32
99Bluz28's Avatar
Yeah, $2500 sounds about right for 2 FAST 92 intake manifolds, 2 NW 92 TB's, and 2 sets of Fel-Pro intake manifold port gaskets.
