longer exhaust duration?
Tri-Y are good for NA cars with cams of increased overlap. If you blow, then 4-1s are the best bet.
All things equal, a short 4-1 and long 4-1 setup of equivalent pipe diameter will not theoretically yield any difference in peak power.
With a set up like his, personally I would prefer a short "reverse split" with 0.570's range lifts and 110 lsa on XE-R lobes.
Something like 228/226, 110lsa. (I've always been a bit unusual)
Proper tuning (Wide band) would be a must.
Longer intake open=bigger charge=bigger bang=more pressure=quicker exit time.
Of course this is under normal atmospheric pressures and not under boost.
Someone may ask me: So why do stock cams play more on exhaust? and the answer is simple: Emissions.
I read an artical somewhere and came up with this theory. Please refute me if I am wrong.
But just to let you Know, Colonel one of the cam GURUs here makes 420 with a 224/220, .581/.581 116lsa (MTI stealth 2) and a good set of heads. Sounds stock too
Overcaming doesn't make sense to me.
If i were to put JBA's on my 01, I would gain maybe 2-3 rwhp max. They are restrictive.
BTW I'm not bashing, just my view of things.
You're extremely overcamming for a target rpm, but if you're wanting to follow the herd...you're on the right track.
What cam would you recommend?
Thanks
John
Put that in your pipe and smoke it! The bigger the cam you put in the more power the motor will make period. You will run out of piston the valve clearance before you can say that motor is overcammed. Why don't you elaborate on a situation where the person was overcammed. These long durations just move the power band up to higher rpms and my target range is pretty mild rpm range. I will probibly be shifting at 6800. Lets hear you fire back now.
JUST KIDDING!!!
LS1Tech.com...the land of 12 second BIG DYNO DADDY cams and 10 second baby cams...go figure.
