longer exhaust duration?
However it is obvious that 52172 doesn't want to listen to experience. In any case he will learn, by hook or by crook. Nothing like a couple of dissapointments to put you on the right track.
Still I will agree with JRP in his initial choices, my commercial choice would be a 228/228, 114, but for the love of God, get rid of those shorties. If you hate LT's go with MAC mids.
What's your caffeine intake look like?
J/K
So what kind of ETs are you expecting anyway? I see big words, let's see some big numbers to go with them.
ps. all with JBA shorties!
i used to think like you until people like DenzSS and Jrod and the FMS results openned up my eyes.
Your slip at your track Vs my slip at mine (The only one within 1870 miles radius), let us say next October. I'm sure we should be fully ready by then. I can promise you my cam will not be anything bigger 224.
Your challenge is accepted, I'm bookmarking this thread for future reminder.
Cams with higher overlap will make an average of 1-2 rwhp more per positive increase N/A
Expl: (224/224) 112lsa is (224+224)/2 - (112x2) = 0
(224/222) 110lsa is (224+222)/2 - (110x2) = 3
So the 224/222 110 will make rouighly about 3 to 6 rwhp more than the 224/112 N/A.
Now with N2O this still holds true up to 150 rwhp shot. Why is because with a bigger charge = bigger bang = more pressure, which makes the gases exit quicker.
Therefore the longer duration split is not a factor untill 150+ shots.
I guess the questions are really what is your intended use/what is your end goal?
Thanks for the good info to those with constructive input.
If you want higher lifts just get a cam that has them in the first place.
Also the place to look is your powerband and what are you using it for. Personally I've always been a fan of high torq/medium revving cams, just simply because I make up for the top end by spraying.
Also a lot of poeple look at high duration and stratospheric lifts, while they can achieve the same results with "smaller cams", taking into account overlap and lsa.
