longer exhaust duration?
even bigger. Will a longer exhaust duration help with my exhaust set up?
Comp 216/220, 0.525/0.532 114 lsa would be good for you for around 370>380 rwhp with a pulley.
You could always addnitrous if more power is desired
I have no cats and also a electric cutout when needed. I will not be using my SLP 1:85 rockers I will use my stock ones with this new cam. Back to my main question for the third time will a longer exhaust duration make more power with my exhaust set up?????????????????????????????????? its only one question. Also I am going with a much larger cam than the one you mention that is a puny cam I want 230 and greater durations with up to .625 lift I will be running 921 dual valve springs or the new patriot dual valve springs good to .650 lift.
Because there is a bigger charge to exit through the exhaust, therefore more exhaust valve opening time.
With unported exhaust port (Less cfm) and a more restrictive exhaust manifolds, exhaust valve need to close quicker. So a reverse split will do just that and be more efficient for max power.
