Compression ?
Old May 2, 2004 | 01:57 PM
JZ'sTA's Avatar
Default Compression ?
I have a 6.0 block with 5.7 heads. Because of the pistons I put in the motor, the Compression came out to 11.85. I have a set of 6.0 heads on the way that have no flycuting done. What will my new CR be with the 6.0 heads?
Thanks
Old May 2, 2004 | 02:01 PM
PREDATOR-Z's Avatar
What size CC??
Stock unmilled 6.0 are like 71>72 cc and that will net you around 9.3>9.1 respectively with a stock graphite gasket.
Old May 2, 2004 | 02:22 PM
JZ'sTA's Avatar
Originally Posted by PREDATOR-Z
What size CC??
The CC is stock I believe 71.06
I know what a stock LS1 with stock 6.0 heads would be but what I am wondering is what the compression would be with my setup. It is a 410 Cubic inch motor and with stock LS1 heads the compression is at 11.85.
I am trying to figure out how much compression I will loose when adding stock 6.0 heads. (Of course when the heads are done they wont be stock, but for now this is what I am needing to know.)
Thanks
Old May 2, 2004 | 02:35 PM
PREDATOR-Z's Avatar
oops didn't read that! What kind of slugs?
Old May 2, 2004 | 02:49 PM
JZ'sTA's Avatar
What is a slug?
Old May 2, 2004 | 03:23 PM
PREDATOR-Z's Avatar
Pistons! dished? flat tops? domed? half moons?
Old May 2, 2004 | 06:31 PM
JZ'sTA's Avatar
Never heard that name before. They are flat tops.
Old May 2, 2004 | 06:41 PM
jrp's Avatar
jrp
SN95 Director
http://www.rosspistons.com/calculator.php
Old May 2, 2004 | 06:51 PM
JZ'sTA's Avatar
Damn this almost worked. I am smart enough to get the right cubic inches but not smart enough to get the right compression.
Damn.
Old May 2, 2004 | 06:58 PM
jrp's Avatar
jrp
SN95 Director
Damn.
no offense but if you cant figure it out how are we? how many cc's are the pistons domed, are you using stock gaskets as well or a different size.
Old May 2, 2004 | 07:01 PM
jrp's Avatar
jrp
SN95 Director
just got your pm.
your not entering the CC's of the piston dome. i.e 8, 10, 12 ect. also that gasket is way thin
Old May 2, 2004 | 07:08 PM
jrp's Avatar
jrp
SN95 Director
i come up with 11.7 CR using stock gaskets, 0 deck height and flat top pistons but you said your were domed.
JZ'sTA's Avatar
Stock gaskets. The piston's are flat top's and therefore wouldn't have any dome correct???
Old May 2, 2004 | 07:11 PM
JZ'sTA's Avatar
With a flat top what should I enter in that field?
And what is the size of stock head gaskets?
Old May 2, 2004 | 07:15 PM
jrp's Avatar
jrp
SN95 Director
pm sent. i thought you said they were domed not flat toped. flat top would be 0. stock graphite gasket compresses to .052-.054
Old May 2, 2004 | 07:21 PM
JZ'sTA's Avatar
Cool I figured it out. I was missing a 0 in the head gasket part. I entered .xx when I was supposed to enter .0xx (.054)
Thanks
