Camshaft choice worried about DCR
Hey guys I have a question regarding my Camshaft and DCR. I have a lq4 block and 799 heads. Heads are at the machine shop now, he just did a clean up pass on them .04 or so. I should be around 11:1 comp ratio. The cam I went with, now im not married to it if its going to be an issue i will get another, the cams a
Comp LSR 269lr hr12
269 277
219 227 @ .50
.607 .614 112deg
inlet valve closes ABDC 62 deg
I used wallaceracing.com DCR calculator with my elevation being 850ft and My Comp ratio at 11:1 came out to be 8.79:1 DCR is this going to be an issue with detonation or other problems? Considering that I have a proper tune. What do you guys think ?
Comp LSR 269lr hr12
269 277
219 227 @ .50
.607 .614 112deg
Comp LSR 269lr hr12
269 277
219 227 @ .50
.607 .614 112deg
Comp LSR 269lr hr12
269 277
219 227 @ .50
.607 .614 112deg
Be careful with the Wallace calculator. You would be better served by the uempiston calculatoe which takes chamber size and other factors into account. The Wallace will get you a ballpark number if you already know your static compression. Even then, it is still dubious.
Old School Heavy
Comp LSR 269lr hr12
269 277
219 227 @ .50
.607 .614 112deg
Comp LSR 269lr hr12
269 277
219 227 @ .50
.607 .614 112deg
I rebuilt the bottom end with speed pro flat tops thats how I came up with 11:1. I called comp they said I'm going to have an issue with that cam recommended and xer grind 232/234. I'm going to give Texas speed a call. I redid the dcr calculation with the uempiston program and it came to 9.04
221 then minus 180 for a total of 41 degrees ABDC...pretty early...trapping
lots of cylinder pressure. This makes for a smooth idle, good street torque,
and usually decent mileage (gear and converter dependant)
