Loud Ticking/Tapping Noise from left side of engine bay
So, to start off, I have a 1998 Formula with 312k on it right now.
The other night i was driving it about 10-15 miles away to a little car get together. Well after pulling off from a redlight after half of the way there, there is this LOUD ticking/tapping noise. Now the car had an exhaust leak before hand, so i know what that noise sounds like.
I'm just looking for possible suggestions/views on what it could be. We are tearing the car down in the morning, so i havent gotten to look inside yet. But i was wondering what else besides: dropped lifter, loose/broken rocker arm, or maybe a bent rod(somehow) to look for?
I did read on another LS-based forum that the oil pump seal can go bad, causing aeration to get into #7, causing the lifter to act funky. Any one else had this problem or know of its validity?
It really could be so many things with that high of mileage...just look over everything good and plan on getting a full gasket kit (around $250-300) for everything.
Good luck and let us know what you find!
