700hp With A 408 Possible?
Old Sep 26, 2013 | 07:51 PM
Rise of the Phoenix's Avatar
Originally Posted by Gray86hatch
Making that kind of power is going to require about $6500 in heads and intake. Solid roller. so another $1200 in cam and lifters. 8000 rpm Nothing gets cheap about it. Trust me I am looking at $5000 out of pocket to sell my stuff and put a set of full tilt mast heads that will make 760-770
Tim
Your setup is already stout as ****.
Old Sep 26, 2013 | 08:22 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Originally Posted by cfiester
i got 724HP 602 ft. lb torque out of 425 cu. in. LS2 block. Eagle rotator. LS3 heads ported by bowers out of Ft. Collins. Holley tall efi intake, 92mm intake. I think we used 45# injectors. 91 Octane at 3800 ft. elevation. Gibbs oil. lots of dyno time. Lots of ZOTARS $$$$$$ The holley tall efi intake is a tight SOB in a fourth gen.
Say-you got any pics of this?
Old Sep 26, 2013 | 08:29 PM
Sinister_Z28's Avatar
So exactly what heads would i be looking at to do this or get close? Whats a ballpark on cam specs? And how do u determine what is a safe max rpm, is the valve train the limiting factor or do u have to take into account things like bearings and length of the stroke?
Old Sep 26, 2013 | 08:36 PM
You want cathedral or square port. For cathedral, TFS 265cc or All Pro heads. Square port heads, you could go with Mast.
Old Sep 26, 2013 | 09:25 PM
I really dont care which. I just want the best one for the job. Currently im running LSA heads and a ls3 intake on it right now. Which Mast head would u recommend.
Old Sep 26, 2013 | 09:34 PM
I'd talk to Mast and see what they say. If you got the cash, you might as well go with their 2 piece intake too.
