Difference in early and older LQ4 motor?
Old Sep 16, 2013 | 08:35 AM
blue89irocz's Avatar
Default Difference in early and older LQ4 motor?
I am new to the site and am researching the LQ motors. My question is, is there a difference in the later to newer models? I am looking at doing a single turbo build for a street/strip car.
Old Sep 17, 2013 | 06:48 AM
A.R. Shale Targa's Avatar
Some say that GM improved the rod bolts in the 00-01 era and IIRC the 03
engines have the teflon coating on the piston skirts for quiet startup and
less friction
Old Sep 17, 2013 | 08:23 AM
badazz81z28's Avatar
I was under the impression the only difference was the later ones had aluminum vs cast iron heads...
Old Sep 17, 2013 | 07:52 PM
JWAbercrombie's Avatar
Early lq4 has cast heads and the crank is longer in rear, head bolts are different length compared to newer motor and they have press in wrist pins. And I been told older lq4 has different reluctor wheel. Not 100% on last part though...
People have put aluminum heads on them and made good numbers but from what I've been told your better off to find an aluminum motor just due to it being more up to date with the ls1 type set ups
Old Sep 17, 2013 | 08:21 PM
radchevy's Avatar
the 2000 and older LQ4s have a longer crank shaft. no one make a after market flywheel. I have been there had to change out the crank to put a sfi flywheel on it.
Old Sep 20, 2013 | 08:00 AM
Alright thanks folks
Old Sep 20, 2013 | 06:00 PM
RezinTexas's Avatar
sometime in '04 the changed the length of head bolts, and got the "LS2 style" rods with press-fit pins. That's also around the time that flex fuel and DBW started.
Old Sep 21, 2013 | 11:11 PM
1FastBrick's Avatar
99-00 had cast Iron Heads and a special longer Crank shaft that will only work with the 4L80E.
Starting in 01 they used the standard crank with a spacer between the flexplate. They also went to the 317 aluminum heads with MLS gaskets.
01-late 03 had 3 different size head bolts lengths and pressed pin LS1 style rods
04-07 had 2 different size head bolt lengths and should have the LS2 style rods with Floating pins.
Not sure exactly when but GM introduced the garfel coating to the sides of the piston to reduce the piston slap around 03.
As far as the throttle body goes it depends on the application. They had cable actuated TB's on the Vans all the way up through 2006.
Old Sep 22, 2013 | 06:08 AM
RezinTexas's Avatar
my '04 LM7 had LS2-style rods and press fit wrist pins. I would imagine that some 6.0's got this as well.
Old Sep 22, 2013 | 01:37 PM
1FastBrick's Avatar
I have never seen an LS2 rod with a press pin.
I have seen some early 04 units get LS1 rods with Press pin's. That applies to every engine in the LS family.
The LQ9 had the floating pin introduced in late 2003 as the second design.
For example If you look up LS1 Pistons for a 2004 corvette in the GM parts system there was a design change in 2004 were they went to the Floating pins.
Old Sep 24, 2013 | 04:58 AM
RezinTexas's Avatar
my '04 LM7 did, here is how I disassembled them
Old Sep 25, 2013 | 12:50 AM
1FastBrick's Avatar
Do you have a pic of the small end after the piston was removed???
Old Oct 6, 2013 | 05:45 AM
RezinTexas's Avatar
here is a pic I found in my file.
Old Oct 6, 2013 | 10:38 AM
Thanks guys great info.
