Stock rocker carnage *pics included*
Old 09-25-2013, 09:55 AM
mjs1012's Avatar
Im glad I did the trunion upgrade for my cam swap.
Old 09-25-2013, 11:12 AM
kinglt-1's Avatar
Originally Posted by RockinWs6
BS the lifters won't jump out geez. Even if they did they can't go anyplace....ever see the inside of a LS engine?
Wait I just thought a little more about this....you actually think the lifters can come out of their bores if no pushrod is on them...hmmm then why doesn't it happen when someone breaks a pushrod.......
Its completely safe to run this way.
Bath salts ehh?
Old 09-25-2013, 11:20 AM
hlujan's Avatar
I'm going to pull the heads should I port them, or buy some different ones
Old 09-25-2013, 01:45 PM
PREDATOR-Z's Avatar
Originally Posted by bozzhawg
puff puff pass
Here, pass back, ....
Old 09-25-2013, 01:53 PM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
Originally Posted by speedtigger
MS4 had a pretty aggressive intake lobe. That is a lot of stress for driver.
This. On a sidenote, OUCH.
-Garrett
Old 09-26-2013, 05:45 PM
td1168's Avatar
Is it good stuff?
Old 09-27-2013, 11:46 AM
wildcamaro's Avatar
If I blow a head gasket I think I'll just remove one of the heads and just disable that bank lol
Old 09-27-2013, 12:57 PM
03Sssnake's Avatar
Old 09-27-2013, 04:26 PM
RockinWs6's Avatar
I think ya all are smoking monkey spunk err sumtin..........
Old 09-27-2013, 04:27 PM
RockinWs6's Avatar
I am not talking about the lifter jumping out of the top of the tray, I am saying that the lifter can fall back down in contact with the camshaft from the up position in the tray. With no pushrod, there is no spring pressure to keep the lifter riding smoothly on the camshaft. So the lifter can smack into the side of the lob instead or riding up the lob. This is when things break.
This even happens to some when the motor is at rest during a camshaft change. This is why most use wood dowels and/or pen magnets to hold the lifters up during the cam change.
As for the broken pushrod thing. It does happen sometimes. Also, most people aren't stupid enough to drive hundreds of miles on a bent or broken valve train.
I seen many a ls1 with broken pushrods driven many miles...........
Old 09-27-2013, 04:41 PM
SladeX's Avatar
Just because you can drive Florida to New York with a broken lifter and wiped cam lobe does not mean that you should do it...
On another note I spun a bearing a few months after replacing the cam and lifter...
Old 09-27-2013, 04:58 PM
  #32
RockinWs6's Avatar
Yeah these all aluminum engines are fickle to say the least. Way too many variables, everyone runs different and has different problems. Most LS1 cars suffer from oil usage and if you don't look after that bad things happen quickly.
Old 09-27-2013, 11:47 PM
  #33
wildcamaro's Avatar
They are way too fickle if you don't know what you're doing...Ls engines are by far one of the easiest and most reliable engines out there..
Old 09-28-2013, 02:23 PM
  #34
hlujan's Avatar
So what should I do for heads when I pull these of to fix that valve... Port and polish them? Or get some 243...ect ect? Really on the fence on the heads..
Old 09-28-2013, 03:27 PM
  #35
Old School Heavy
speedtigger's Avatar
http://texas-speed.com/p-4-prc-stage...ted-heads.aspx
Old 09-28-2013, 03:45 PM
  #36
chevybayboy's Avatar
Originally Posted by td1168
Is it good stuff?
I'm from.CA and haven't smoked anything as good as that guy lol
Quick Reply: Stock rocker carnage *pics included*
