just out of curiosity
Old May 4, 2004 | 12:16 AM
pbjones81's Avatar
Default just out of curiosity
I dont know a whole lot about engines, but i wondered something. if you took a stock LS1, and put a set of non-ported 6.0 L truck heads on it (lowering the compression to 9:1)..... then you took it and put a blower (8 lb maybe) on it with a 150 shot nitrous kit, what would this yield? a monster? or a slow POS?
Old May 4, 2004 | 11:22 AM
technical's Avatar
slag...
Old May 4, 2004 | 11:29 AM
DenzSS's Avatar
8psi @ about 9.5:1 compression intercooled equates around 550hp. Add 150 shot of NO2 and you have pieces of broken engine laying under your car.
Old May 4, 2004 | 03:14 PM
pbjones81's Avatar
Default .
that sucks, but youre saying that without the Nitrous, it would be a good setup? does anyone have this setup that can speak from experience?
Old May 4, 2004 | 03:25 PM
DenzSS's Avatar
I'm speaking from experience. I've worked on somewhere around 30-40 supercharged LS1/LS6 engines. 8psi is right at the limit of the stock components. Sure, you can go higher than that but it won't last long.
Old May 5, 2004 | 08:18 PM
pbjones81's Avatar
Default .
ok. if an LS1 with 8lb boost on 9.5:1 CR 6.0L truck heads equates to about 550 hp, then how much horsepower would 8 lb. be on a stock LS1 10:1 compression (stock heads?)
Old May 5, 2004 | 08:43 PM
pdd's Avatar
pdd
ouch
Old May 6, 2004 | 12:52 AM
z98's Avatar
z98
8 PSI doesn't mean anything. PSI is a measure of restriction, not power or airflow.
8 PSI on 6.0 heads isn't 8 PSI on LS1 heads.
If your tuning was right on, you'd have a great setup. But it probably wouldn't last.
Check Rob Raymer's forumla out, he was putting 700+ to the ground with a stock motor. Not something I'd try, but he's doing exactly what you're talking about.
My advice: if you're going to all the trouble of FI + nitrous, spend the $2800 at a sponsor and get a small cube forged short block. Well worth the money.
