Engine falling over at 5800rpm
Cheers. They will be fitting them tomorrow 'our Monday' I do believe this is the issue also.
If it proves correct I will get the trunion upgrade.
Well, the Stock rockers were fitted today, the car run on the dyno & the engine nose dived at 5800rpm.
The tuner said the bad harmonics that had been there were now gone but believes the nose dive is valve float
I am just praying now that the BTR springs fix this thing.
I am out of cash & out of patience, the cars been down now since 28th July
I needed to get these from a single source & not have a 3rd party involved like Comp for Trunion upgrade & BTR springs from else where.
Ah well, sometime within 2 weeks I will know if this will work.
This had obviously been happening with the Comp lifters I had been running & later with the LS7 Caddi lifters I had put in, so don't believe it's the lifters.
like to see the end results, i am running patriot stage 3 heads on my 402 with the gold springs, in the begening i could spin the engine to 7000, now it will nose dive at 6200 on the dyno graph, cam is 236-242 and crane 1.8 aluminum adjustible rocker kit, looking at swaping in some springs this winter, looking for the best springs and keeping my 1.8 adjustable kit.
Well I got a ph call today from the tuner,
The rev limiter had been set at 6700rpm & the first pull hit the limiter, 2nd & 3rd pull on all accounts it starved for fuel at 6500rpm. I have a Walbro in tank fuel pump fitted so they are going to change the fuel filter & try again then check what the pump is flowing.
As for my inital problem of lack of revs & nose diving, it appears this is now behind me....I HOPE.
This has been a 2 part issue....Harlan Sharp rockers being to heavy on the nose I guess causing bad Harmonics with the smaller cam & Pac 1518s, then after fitment of the Tick sns stg 3 & my used dual Patriot golds, 2 issues then became apparent, the rockers & then the springs.
ATI Damper is standard & Brand new
Not quite fixed, till it can rev without fuel starvation.
The dyno it's being tuned on reads extremely low numbers.
Where I had been reading 408rwhp with small cam on my usual tuners dyno, this one read 332.5rwhp.
So as a base run I will see how much improvement on the 332.5rwhp this new cam etc has done until I can afford a power run on my usual tuners Dyno.
good to see you got it going in the right direction.
