Power Sealed Lifters?
Old May 4, 2004 | 02:46 PM
MYBLKSS's Avatar
Question Power Sealed Lifters?
Have you guys ever heard of them. One of my lifters has been sticking off and on for over a year now, but I have been putting off changing them because GM replacements are $44 a piece. 44 x 16 = $$$ So I want to advanced auto parts the other day and to my amazement they carry power sealed OEM replacement lifters for $8.07. Is power sealed a respected name, will these lifters hold up to 918's. They are supose to be OEM replacement so I am assuming they are as strong as the GM units. Any feedback would be great.
Old May 4, 2004 | 02:59 PM
NOBR8KSS's Avatar
An $8 hydraulic lifter? They are probably mistaken...I bet they are telling you a lifter for a small-block chevy. A SBC lifter will not fit the LS1.
Comp Cams has a high-quality OEM replacement set for about $200. Many of our sponsors carry them.
Here is a link:
http://www.texas-speed.com/item_deta...?ProductID=316
Old May 4, 2004 | 06:47 PM
Unaffliated Racing's Avatar
that is where you are wrong..the LS-1 lifters are exactly the same as the SBC roller lifters..SBC,LT-1,LS-1...are all the same
Old May 4, 2004 | 10:45 PM
Randy WS6's Avatar
I got mine from Advance and thay are Seal Power lifters and thay will fit from 82 to 03 GM These are NHRA aproved lifters, thay cost me $118.00 and i have Patriot Gold duel valve springs love them no prolbems at all
Old May 5, 2004 | 06:45 AM
MYBLKSS's Avatar
Randy WS6 Thanks for the feed back. I am glad to hear your happy with them.
Old May 5, 2004 | 09:25 AM
NOBR8KSS's Avatar
So...why do they have different part numbers?
CC 262-400 SBC hydraulic roller lifter: 853-16 or 885-16
CC LS1 hydraulic roller lifter: 850-16 or 875-16
Just curious?
Old May 5, 2004 | 05:18 PM
Randy WS6's Avatar
Well advance part number is HT-2148 and shows all years that have roller lifter from the factory i beleave from 82-04's the lifter has 2 flat sides that slips in the plastic gides on the LS1 and LS6 and on the older motors has a springs type valey cover that has holds the lifter in line and straight to the cam shaft the lifter can not turn at all eather direction just up and down and some has a (H) bar that sits down on the flat sides on the lifter that holds two together
Old May 5, 2004 | 07:38 PM
853-16 and 885-16 are retro-fit lifters..made for engines NOT originally equipped with roller cams..they are a link bar style lifter
Old May 6, 2004 | 07:25 AM
NOBR8KSS's Avatar
Thanks...sorry for throwing in the wrench
