Finally chose a cam! what yall think?
#41
that cam is fine with stock springs and everything else. All you have to do, it take you stock springs out turn them over, and re install with the reatins and locks. Upside down the stock LS1 springs work fine with 650 lift, They will sit on the valve seals now, and it shims them so have have more spring pressure
the trick is to keep the stock pushrods. So when they run out of spring room the pushrods just bend a little. Then the valvetrain is setup to the MAX spec. after they bend to it.
LS1tech cam tip of the week bitches
Why you gotta tell everybody our secrets?
