Time For A New Shortblock...
Current setup:
Stock 98 LS1 w/Katech rod bolts
243 AI Heads
226/230 AI Cam
Fast 90/90
I dont wanna waste money on the 98 block so the plan is to buy a 370ci TMS Iron Shortblock. Want to keep the rebuild total as close to 3k as possible. So as long as my 243 heads are ok I'll be happy.
Should have some pics tearing down the ls1 tomorrow.
Current setup:
243 AI Heads
226/230 AI Cam
Fast 90/90
Didnt get as far as I wanted today, because the crank puller wouldnt work on the ASP underdrive pulley. Didnt want to force it. Found oil pooled on top of the valves when I pulled the intake. Thinking it came from the intake since the majority/all the valves had oil pooled.
Heres a before pic:
Oil on top of valves:
For a puller, goto Advance and RENT one of their good pullers with a force rod. It'll pop the ASP off without damaging anything.
I made an impromptu force rod from a socket and damaged the nose of my crank snout as seen here:
Are LQ9 blocks pre-drilled for timing chain dampeners? Got lucky on my 98 block and it was, so it'd be nice if i could reuse it.
Pulled the block, and found rod bearings #3 and 4 chewed up. Will pull the crank tomorrow and probably find a couple more chewed up.
Also found out the flywheel dowel pins from my Monster Clutch had been flung around in the bellhousing.
Whats a reasonable price to ask for the shortblock?
Depending on how bad the bearings are, I would think $3-400 would be reasonable asking price for the shortblock, minus the cam, etc.
KCS, what sealer do you recommend? I have both Permatex Blue (couldn't find Loctite around here for some reason and Permatex **** is runny) and Permatex sealant. I believe GM recommends Blue Loctite?
Been shopping around for a new cam. I emailed BTR and he suggested his stg III231/242 .617"/.588" 112+2. Waiting on a response back from Tick.
