5.3 & accessorie options
Old Oct 28, 2013 | 02:02 PM
sardo_67's Avatar
Default 5.3 & accessorie options
I picked up a 5.3 from a suburban, I am installing it I to my jeep Cherokee. The intake and alternator ate too high so rather than changing the hood around I can put the lower car intake on which I plan to do. What else do I have to change and which alt relocation bracket should I use? Ive seen some for $60 and "kits" for $450. I just need something quality that will work.
Old Oct 29, 2013 | 08:22 AM
2muchboostNY's Avatar
Different chassis for me (Nissan) but I am using an LS6 intake with Fbody accessories. You could also use the Vette accessories as well.
Check this article out
http://www.carcraft.com/techarticles...e/viewall.html
Old Nov 1, 2013 | 12:40 PM
sardo_67's Avatar
thanks for the info.
anyone know about running 2 alternators?
Old Nov 1, 2013 | 09:53 PM
janks300's Avatar
i used all the truck accessories with an ls6 intake and an f body low alternator mount, follow this link for how to use the f body mount....it will also work with an ls1 intake which you can pick up for next to nothing
https://ls1tech.com/forums/generatio...r-diy-how.html
Janks
Old Nov 1, 2013 | 10:53 PM
sardo_67's Avatar
thanks but i do still need the power steering pump, also would you think i should keep the alt higher since this is going to be a offroad application?
i don't plan on mudding this or going through feet of water so i'm not sure it would be an issue.
Old Nov 2, 2013 | 12:10 AM
bww3588's Avatar
Janks
How did you space the alternator out to align right with the truck stuff?
Old Nov 3, 2013 | 07:43 PM
oldskoolford51's Avatar
http://www.lsbrackets.com/3LS%20Truc...%20Bracket.htm
i am running this setup in my truck and it fits great and pulls everything in nice and tight
Old Nov 3, 2013 | 07:54 PM
LS1MCSS's Avatar
Looks like you'll play hell checking/adding power steering fluid with that setup.
Old Nov 3, 2013 | 09:10 PM
its not as bad as the picture looks. but it helped with the clearance between the power steering pump and the steering box.
Old Nov 4, 2013 | 04:13 PM
OLDSKOOL....got any pix of how you plumbed the turbo? I cant tell from the pix if my flipped truck mani's would run into any issues with a similar setup.
Old Nov 5, 2013 | 11:59 PM
im not running a turbo wish i was lol
Old Nov 6, 2013 | 08:37 AM
I have got to lay off the booze while on this forums.....lol my bad.
