Best cam for patriot ls6 heads stage 2
I have a 2001 camaro with full exhaust. I just picked up patriot ls6 heads stage ii heads. What would be the best cam for this set up?
The best cam for the setup is determined not only by the parts you already have, but also by how you drive the car and what you use it for. Is it a daily driver, weekend warrior or purpose built drag car? What desired RPM range are you looking at? Lots of questions need to be answered before anyone can direct you on the "best" cam. In my opinion, it's always best to have a proffessional customize the cam based on your parts and how you plan on using the car. Martin at Tick Performance is great to work with and will lead you in the right direction.
