Undeerdrive pulley/balancers..feelings?
#61
wow and I thought some of the small block/big block arguments back in the day got gnarly.
I think the main thing is to upgrade to a good quality dampener whenever you do heavy mods because the stock and a majority of the cheap dampeners are only tuned for a specific set of parameters. Now as far as fluidamper versus ATI it's is pretty much blondes vs redheads sure the one is easier but the other is more fun, sure she might stab you in your sleep but hey everything is a risk.
As far as engine go nothing is going to last forever and spark ignition engines are lucky to last 500K. Check your budget and decide appropriately whether you want easy or stabbed in your sleep.
#66
ATI 25% underdrive
What do you guys think of this one? ATI 25% underdrive pulley. I'm looking for quality damping over underdrive but it is an ATI. Do you think some dampening is sacrificed for the smaller diameter? ATI 918844
#67
I never did say the ATI was a bad balancer...I'm stating what do you have to show the SLP/PB pulleys is so inferior? You keep bringing up Corvette failures...But LS engine are in F-body/GTO/G8/trucks and there are a hell of lot more of them out there than Corvettes. Where are all the other failures?
To prove the difference someone could do a test. Have 2 identical freshly built engines on a dyno (one with ATI/fluid, and when with ASP/SLP/PB) hold the RPM's between 4300 and 4800, and see which lasts longer.
#68
I see pb, slp, ati have been discussed. But I have a trick flow ud pulley on mine. I dont know if it's 10% or 25%, don't know how to tell either. When I bought my car a little over a year ago it was on it already. Has anyone had any experience with them to know how well they dampen? Never seen anyone else running a trick flow ud pulley
