Help!!! Needle Bearings In Oil!!!
Old 05-06-2004, 04:06 PM
TA_HOOKER's Avatar
Question Help!!! Needle Bearings In Oil!!!
I am new to this site but was referred to help with a problem.....here it is.....
I took my car in yesterday to get the oil changed and rotors turned and just a general check up before Norwalk....
I get a phone call from my friend at the shop and he tells me I need to get back over to the shop...
My first thought is maybe I should get a new mechanic if they can't change the oil and rotors by themselves.....
So, I get to the shop and my oil plug is laying on the counter with A LOT of metal bearings stuck to the magnet.....
(P.S. This news comes one week before Norwalk and one week after an estimate for over $1500 in work that needs done on my truck)
Long story short we can't figure out exactly what's wrong till we tear the engine apart and not only that but my TA only has 40,000 miles on it!!!!!!!!!!!!!!
So....do I let them tear the engine apart???? Has anyone else ever had this problem???? How does this happen????
I hope someone can give me some answers to these questions????
Old 05-06-2004, 04:08 PM
XFiveLiter's Avatar
It's just your rocker arms. DO NOT TEAR DOWN YOUR MOTOR!!!
BIGBOS's Avatar
How big are these "pieces"
Whens the last time you changed the oil, are you burning oil, does the motor knock at all..cold/hot?
Old 05-06-2004, 04:09 PM
LS1TECH Sponsor
Steve Burger's Avatar
Pull the valve covers and find the rockers that died. What you found are needle bearings from the rockers.
Old 05-06-2004, 04:11 PM
TA_HOOKER's Avatar
Changed oil 3,000 miles ago.....not over burning oil....no noises......actually I am very lucky I took it in before Norwalk(race) or something really bad could have happened.
pieces are about this big ___ and pretty thin....
Old 05-06-2004, 04:13 PM
TA_HOOKER's Avatar
[QUOTE=TA_HOOKER]Changed oil 3,000 miles ago.....not over burning oil....no noises......actually I am very lucky I took it in before Norwalk(race) or something really bad could have happened.
pieces are about this big ___ and pretty thin....[/QUOTE
Okay, found the rocker problem but now do I need to replace all or just problem one..????
Mechanic is on the phone.....
Old 05-06-2004, 04:14 PM
BIGBOS's Avatar
Replace the problem, check over all others to make sure they are good as well....
WAHUSKER's Avatar
Yep, sounds like needle bearings from the rocker arms alright.
Old 05-06-2004, 04:32 PM
TA_HOOKER's Avatar
Mechanic just called and intake was leaking too, so new rocker, new pushrod, new intake.....and we should be good.....
thanks for all your help.....
Old 05-06-2004, 04:34 PM
BIGBOS's Avatar
Intake gasket?
Old 05-06-2004, 04:38 PM
TA_HOOKER's Avatar
Intake gasket?
Hell, i just drive em....LOL... i don't know....I would assume what ever is connected to the rockers and pushrods.....
Old 05-06-2004, 04:51 PM
93TAWicked1's Avatar
Never heard of an intake leaking before......
Old 05-06-2004, 07:50 PM
LS1TECH Sponsor
badpewter-z's Avatar
all they can really leak is air if i remeber correctly
sounds like the mechanic is slow and needs extra work , new call now you need this, now you need this too
Old 05-06-2004, 11:02 PM
blue by you's Avatar
you should have the mechanic check for any "bulletins" for your car. i am a GM tech and if i recall, there was a "bulletin" out on our cars for that exact problem. if i'm right, you might be able to get them replaced at no cost. i would have to check at work tomorrow for sure. but check it out anyways.
