Mast LS3 on LS1. Anyone running them?
346 ls1 with arp rod bolts no flycuts
Isky 243/250@109 camshaft
Custom adj Jesel rockers 1.7
3/8 pushrods
K800 .700" dual springs
Morel street link bar lifters
Shaved .030 off the heads
Cometic .040 gaskets
Std ls3 intake 92mm tb
OTR intake, k&n filter
Customised circle d converter, 5000 stall speed
Built 4l60e
Pedders xa coilover suspension
265/40 18" et streets
3/8 pushrods
Built 4l60e
3/8 pushrods
Built 4l60e
3/8 pushrods
Built 4l60e
The Scammer Hammer
Having good discussion about these with Ed. Probably about two weeks out or so from pulling the trigger. Should chime in around 3300 for the pair. That's with hollow intake valves, billet stands (for stock rockers) and upgraded springs with Ti retainers.
Not bad if you think about it.
Price Mamofied AFR's. About on par, heads alone.
Price TFS 215's or the like. A bit cheaper, yes, BUT, don't forget that Fast intake...
I can run these, an LS3 intake, injectors and rails, with a 90mm LS2 TB.
#35
E85 yep
The 47's are rated that at 42psi, I'm running 70psi fuel pressure to try help. I have a boot mounted surge tank with twin walbro pumps and a fuel cooler. Aeromotive 1000hp regulator.
I'll upgrade the injectors when I can afford to but my tuner reckons they are just ok for now.
Having issues shifting early on the 1-2 shift (6100), haven't really had too much time to sus it out properly but spin it 7200-7300 on the 2-3 shift. Standard tacho only goes to 7000.
I don't have a Dyno sheet, only a pic of the Dyno screen. They didn't believe the numbers it made so told me to back it up on the black stuff first. 324rwkw roughly 440rwhp, huge roller torque due to the unlocked converter. Highest h/c ls1 figure on their Dyno yet, even with similar combos with other brand heads with m6 transmissions.
So I'm pretty happy with the mast heads even with the dollars outlaid, I'll just upgrade the bottom end one day
#37
It sounds amazing north of 7000 revs though.
I wouldn't mind changing the cam to something else if I can make more power, this cam was only a guess being it has ls3 ports with ls1 sized valves.
Also want to shave the heads to get the compression up to 13:1 next year with some fly cuts and see what these heads can really do
#38
Just standard tacho, and no shift light, just rely on the tune
I'm in the same boat as you. When I switch to a Super Victor/4150 TB setup, I'm going to get a new cam (much bigger), pull the heads off to be milled and do some flycutting and get to 12.5:1 compression. I think that will be safe on 93. Since you are on e85, 13:1 will be good. Hell, you may be able to go higher if you wanted to.
#39
I spec'd the cam myself, thought it would fit with the extra clearance these heads have. LS3's tend to like about 7 deg split but LS1's like a lower lsa.
It's nothing special, lobes straight out of the catelogue lol
How much compression is too much for the standard ls1 bottom end?
#40
If you do go with another cam, I'd have someone spec one out for you. Ed or Martin would be my two top choices.
