My JPR HVLD Head flow numbers
I don't know anything about Joe.... but I do know this. The heads that came into my Shop from Jim which he claimed Joe ported.... were a JOKE! The ports were inconsistent, the short turn sucked (biggest reason they didn't flow for ****), the rocker boss was still there, blend job was inconsistent.... but what bugged me worst.... you could still see grind marks all over the ports. Nobody took the time to sand them.
I did the best I could with what I know to fix them.... but you can only do so much and when the short side is already layed back... well it doesn't leave you alot of room to shape the port like you want.
I would rather have run stock heads than what showed up in the shop. But after working them over, they're not too bad.
An update on me:
https://ls1tech.com/forums/showthrea...72#post1352172
11 Bravo, I will flow your heads if you want, at no cost.
That is a great offer and very gentlemanly of you.
I too think that Joe can port heads, he just has to have his head clear of other distractions. That is why I though when he got to JD's it would work out great, but there was so much baggage that the JPR name brought into that venture that it was doomed to start with and then the downhill slide began.
U know AtoZ Performance,we bought your S3 LT1 heads off u a few weeks back.
And some Jesels a while ago too
Brain Tooley I know Joe can port too when he has his mind clear
But just like I told JD------>BE CAREFUL.
Capability means nothing if the shop your car is at is rushing to get you out the door to do more crappy work on the next car. I have seen this from more places than JPR and I am getting tired of paying for OTHER peoples mistakes.
Then is spewed coolant like a stuck pig.
Consistancy is whats important..
Not one runner after the fact,if he wouldve taken this type of approach with all his customers he wouldve been rich.My car was proof af that,How many S1/TR224 cammed setup do u know that ran 11.30@118 at 3460lbs
I didn't get any flow sheets with my JPR S2 HVLD heads. IMO, consistency is just as important, if not MORE important, than ability when porting heads. ALL the ports need to flow well, not just one of them.
