Shimming Valve Springs for Boost?
i went on Texas Speeds website to look up the Specs of the springs.
it says installed height of 1.810. Do you guys recommend going a little heavier on the seat because i'm putting some boost behind the valve?
Cam Specs http://shop.brutespeed.com/Comp-54-4...-54-479-11.htm
BTR Lifters
8-10psi of boost
stock rockers trunion upgrade
stock ls1 valves
243 heads
spinning to 7000rpms
any recommendations would be appreciated
Thanks
Anthony
link to the spring information
http://texas-speed.com/p-474-precisi...retainers.aspx
BTR Lifters
8-10psi of boost
stock ls1 valves
243 heads
Thanks
Anthony
Thats alot of duration for a turbo cam IMHO. If you are going through the trouble of turbocharging something why only run 10lbs? Run a small cam, less RPM and more boost. The engine will make more power and live longer.
just would like an answer to my valve spring height question. how do you boost guys usually shim your valve springs?
btw after its a 370 i'm looking to make 800rwhp on 18lbs but again will be with different springs and heads
As long as seat pressure is more than your boost.. you will never open the valve from boost..
And.. once its closed...its even higher forces from inside the cylinder keeping it closed
You need open pressure to be very high to fight lifter "loft"..
So you shim springs up to within .050 or .060 of coil bind to get the maximum pressure possible when open (spring compressed)
