Plan on doing ls6 intake need opinions
Flip the intake upside down and lay the coolant tube over the bottom of it and see where it's touching.. Then just dremel/tin snips the ribs to make a pathway
Second option is buy a ls6 front coolant crossover,and get the truck coolant crossover for the rear which is similar to the ls6 version except it shoots straight up vs outward..
Then you "t" them together and then back to the radiator, if you do it this way you won't have to cut any fins on the intake
Look at the pic for this option
Buy the ls6 steam vent tubes rather than taking a chisel to a composite intake, sure it would work but it isn't the right way to do it and you risk the intake, but to each their own
