408 Stroker Help
Old Nov 29, 2013 | 02:12 AM
Camaro_85's Avatar
Question 408 Stroker Help
Okay first off sorry if this is in the wrong place. Now what are the specifications for the 408 stroker? I know they are generally built off LQ9 motors but I don't know the difference in the bore stroke and that type of stuff. Also is it fine to use a LQ4 motor to build a 408 stroker? Please give me the run down on this.
Old Nov 29, 2013 | 05:10 AM
01 Vert ws6's Avatar
A 408 stroker is a steel 6.0 block bored .030 over , a 4.00 stroker crank 6.125 rods and pistons . A lq4 is the same as alq9 just the pistons are different .
Old Nov 29, 2013 | 12:12 PM
Camaro_85's Avatar
So the stock 6.0 bottom end can not be used?
Old Nov 29, 2013 | 12:33 PM
KCS's Avatar
KCS
Moderator
Nope. Crank, rods, and pistons should be replaced.
You probably could reuse the rods, but it would probably cost just as much to use a decent aftermarket rod.
Old Nov 29, 2013 | 12:35 PM
You can't reuse the rods for stroker they are too short
Old Nov 29, 2013 | 12:41 PM
KCS's Avatar
KCS
Moderator
Wisecos are designed for either 6.125" length or 6.098". The problem would be the pins.
Old Nov 29, 2013 | 12:44 PM
Camaro_85's Avatar
So how should i go about building a 408 stroker then?
Old Nov 29, 2013 | 12:50 PM
KCS's Avatar
KCS
Moderator
4" stroker crank, 6.125" rods, 4.030" bore pistons.
How much abuse this engine is going to take will dictate how expensive everything will be. Bottom dollar budget build I would say a Callies C Series crank, Scat I beam rods, and Wiseco pistons would get you there and hold probably 600whp.
Old Nov 29, 2013 | 12:54 PM
Camaro_85's Avatar
Okay thanks guys, I have been trying to find this information forever and I'm glad i join this forum because I just got the information in hours.
Old Nov 29, 2013 | 09:25 PM
Camaro_85's Avatar
Okay I was looking at Callies cranks, and I'm assuming your talking about the Compstar C Series cranks correct?
Old Nov 30, 2013 | 08:04 PM
garygnu's Avatar
go to Texas Speed website and look around for rotating assemblies .
Old Nov 30, 2013 | 11:15 PM
Sales@Tick's Avatar
For a good budget engine that won't see more than 150-200 max nitrous or just N/A use I'd recommend a Manley Pro series 4" stroke crank, Scat H-beam rods with ARP 2000 bolts and Probe 4.030" bore pistons with Wiseco GFX rings(steel top ring).
This is what we use in our budget engine packages for the most part.
Old Dec 1, 2013 | 01:03 AM
Camaro_85's Avatar
Okay can you guys give me some parts numbers?
