ATI Super Damper Install Q
Old Dec 10, 2013 | 07:48 AM
gagliano7's Avatar
I hate when companies use bolts that you need to buy a special to to use when they could have used a normal bolt. Pisses me off!!!
Old Dec 10, 2013 | 09:45 AM
01ssreda4's Avatar
You're in the wrong hobby then fella. You're setting yourself up for lots of heartbreak and aggravation with that attitude.
Old Dec 10, 2013 | 10:03 AM
JakeFusion's Avatar
Super Hulk Smash
Exactly. The aftermarket doesn't care about price. Only about what works.
Old Dec 10, 2013 | 11:13 AM
Burken01's Avatar
Yup they do it on purpose so we buy more..
Old Dec 12, 2013 | 04:37 AM
VLS1's Avatar
Or you could match them up with regular hex type high grade bolts, couldn't imagine that causing any issues.
Old Dec 12, 2013 | 05:51 PM
Bama99z's Avatar
Got my pulley and head studs today. As soon as the shop warms up a bit I going to install something tonight, just dont know what yet lol!!!
Old Dec 12, 2013 | 08:28 PM
JakeFusion's Avatar
Super Hulk Smash
Now's the time to do it. When it's hot as hell it sucks. At least put a big halogen work lamp or two out there in the shop and it'll be decent. I don't run any heat in my garage and usually keep the door closed with the lights and I can just wear a long sleeve tee and jeans. You're not too far down the road...
Old Dec 12, 2013 | 08:43 PM
Bama99z's Avatar
I hear ya, It's 28 degrees here tonight. Thats a little chilly to me!!! However I did get the head bolt threads cleaned and the studs installed.
Old Dec 12, 2013 | 10:44 PM
Burken01's Avatar
Dang and I've been bitching about it being 40-50 degrees over here at night
Old Dec 13, 2013 | 11:23 PM
Bama99z's Avatar
Jake, are you running an aftermarket crankshaft? If so did you have any issues with your ATI hub fitting on it?
In the assembly instructions it mentions that if you are running an aftermarket crankshaft that it may require honeing the id of the hub to acjeive the remocomendsd .008' press fit required by ATI.
Old Dec 14, 2013 | 04:09 AM
Burken01's Avatar
I believe he's running his stock shortblock with fly cut pistons..
Old Dec 14, 2013 | 11:05 AM
  #32
JakeFusion's Avatar
Super Hulk Smash
Yeah, stock crank.
I honed the end of my crank, because I ruined it with a socket trying to remove the original balancer. That cleared up any issues I was having, and it should be noted that I used an old head bolt as the force rod and was able to install and uninstall the ATI hub like 3 different times with no problem using the same fucked up tool. It's much easier to get on and off than the stock balancer was (we test fitted it on there as well to make sure the depth was right - it never looked like the ATI hub was going all the way on). And it was MUCH harder to remove despite the anti seize being on there too.
Also, go ahead and throw it in some boiling water. It slides on really easily. Also, make sure to put the anti seize on there. Helps a ton.
Old Dec 14, 2013 | 12:51 PM
  #33
A.R. Shale Targa's Avatar
Hell we don't even see 28 at high noon round' here these days. Thurs. morn-
ing it was -2 at 5am when heading to work.....try finding motivation to want
to go out in the garage in that....drinkin' beer and football wins every time !!!
Old Dec 14, 2013 | 02:16 PM
  #34
JakeFusion's Avatar
Super Hulk Smash
I like how the last few days here it has been (high temps): 80, 48, 75, 45, 65, 60, 52, 75, 48 and it's humid as hell. So you can definitely work in those conditions, but you don't know whether to sweat or freeze.
Old Dec 14, 2013 | 03:05 PM
  #35
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Someone said drinking beer and football?
I'M HERE!!!
Old Dec 14, 2013 | 04:56 PM
  #36
JakeFusion's Avatar
Super Hulk Smash
And guns. Can't forget guns.
Old Dec 15, 2013 | 08:05 PM
  #37
joecar's Avatar
Yes, that is too bloody freezing cold here in So.Cal. (I'm in GG).
Old Mar 22, 2014 | 09:42 PM
  #38
Bama99z's Avatar
Originally Posted by JakeFusion
Yeah, stock crank.
Jake, I've got a couple of questions for you about your balancer install. I'm finally getting back to working on my build ( way overdue ).
1. As mentioned previously I am using an aftermarket crankshaft. However I have tried to install it 3 times tonight. I can get it on the crankshaft snout but it likes about .210 before it bottoms out. Is that normal? Did your's bottom out?
2. I am thinking that I may have to hone the hub a bit. I wasnt really wanting too, but I guess I'll have too before it will fit. Darn it!!!
Old Mar 22, 2014 | 10:15 PM
  #39
JakeFusion's Avatar
Super Hulk Smash
Don't hone it. It doesn't look like it goes on very far. But it doesn't have to. My belt alignment is perfect with it. I verified by installing the OE balancer, checked with calipers from the front cover to the leading/inside groove of the serpentine and then did the same with the ATI. They were like .006" difference. Nothing to the belt.
Old Mar 24, 2014 | 05:01 AM
  #40
vettenuts's Avatar
If you are measuring the depth per the service manual the numbers will be different than stock. I pre-measured mine to come up with new numbers to measure in replacement of the service manual values.
