ATI Super Damper Install Q
Old Aug 6, 2014 | 07:12 PM
  #41
stage274's Avatar
Originally Posted by JakeFusion
So, I was going to pop on the ATI damper this morning before dropping the engine back in... and I've hit a snag. It came with three 2" 5/16" bolts and six 1" 3/8" countersunk T40 bolts (as needed).
The problem is I'm not sure I have the right hub for the A/C...
The A/C pulley can go on one of two ways. If you flip it around so that it's flush with the serpentine pulley, the bolts aren't long enough to go through the hub, serpentine pulley, and A/C pulley. So, that leads me to believe it has to go the other way (which would be flush if not for the hub). When I test fit this second way, the A/C pulley nestles nicely inside the serpentine hub with a decent amount of space in between (if no hub is installed). But when you put the hub in between, it's much thicker than the natural space produced by the two flush pullies, and that creates a pretty large gap between the outside of pullies. I can't find what I did with my stock balancer, but I seem to recall my stock balancer didn't have this gap between the serpentine and A/C pulley. Maybe I'm wrong there? If so, everything would be okay...
Note that I have not torqued everything down yet, because if it's the wrong hub, I don't want to have to unseat everything. So maybe some of this goes away, but I'm not sure the gap will go away totally?
Do I have the wrong hub? Seems like it's too thick. Or should there be a sizeable gap between the A/C and serpentine pullies?
See pics, below.
Pulley assembled so bolts can be threaded (and you can see how the lip on the center flange is designed to mate up with the serpentine pulley - but the hub now takes up all the space):
Notice how the center section and outer flange sit in this configuration:
Pulley assembled so it's flush (notice the way the orientation of the pulley center section and outer flange are different that above) Note: this pushes the bolt holes so far away that the 2" bolt cannot be threaded:
How did you do it,the second pic, or 3rd pic..... The second pic, my botls are to long to fit, and run out of thread.... Only the 3rd pic it works right with the long bolts.... And no way can I torque it to come snug.... BTW, my hub is fully mounted on the balancer... Its the AC pulley given me the trouble.... In the second pic version mine also has a gap... I dont know, if I do it like the second pic, I need to use the shorter bolts...
Old Aug 6, 2014 | 07:45 PM
  #42
JakeFusion's Avatar
Super Hulk Smash
I don't recall what I did there, but there is a small gap when you put it together. The long bolts go all the way through - there are six holes and three are incorrect and three are correct. As you bolt it down in a criss-cross pattern, it pulls the damper onto the hub. It's not an interference fit, but it is a good, tight fit. I verified by comparing to the stock balancer. Everything lined up on the engine and it works flawlessly without any squeal (which I had before). See the pic of how it looks once tightened down.
Old Aug 6, 2014 | 09:55 PM
  #43
stage274's Avatar
Cool thanks.. You used the long bolts also.....
Old Aug 6, 2014 | 10:03 PM
  #44
JakeFusion's Avatar
Super Hulk Smash
I believe so. I don't recall having any left over. The long go through all three pieces. I just went and looked. There were six of them that have the T30 countersunk heads (I think it was a T30) and then the three 12-point with the washers.
Not great pics of when I dropped the motor back in.
Old Aug 6, 2014 | 10:58 PM
  #45
stage274's Avatar
I just put it together.. I have a blower pulley, and it was different... But, now I have the AC pulley on right... Thats all I care about... That I have it together.... Nice set up man!!!!!
Old Aug 6, 2014 | 11:01 PM
  #46
Paul Bell's Avatar
That's MISTER MODERATOR
Looking good Jake! How big is this motor?
I'm looking at the ATI Chevy damper page to understand why you needed to add the AC pulley to the damper. The Fluidampr I used for my build came complete and ready to install.
Old Aug 7, 2014 | 12:06 AM
  #47
JakeFusion's Avatar
Super Hulk Smash
Because they use different size pulley combos. ATI has like 10 different PNs for our cars. You can get without A/C, with A/C, 10% UD, no UD, 25% UD, different kinds of rubber, etc. The hub is pretty similar tho.
It's a 346. Next motor is either a 408+Nitrous or a 370+F1A Procharger. F1A is going to punish everything in the car but be easier to drive... so I'm still debating whether or not I want a 900rwhp car on 93 octane. Who doesn't? But the cash outlay is pretty big for the fuel upgrades and all. And everything becomes a wear item at that level.
Old Jun 30, 2015 | 09:43 PM
  #48
wayland1985's Avatar
Digging up an old one: but do you recall putting RTV in the keyway? How'd you go about doing it?
Old Jun 30, 2015 | 10:00 PM
  #49
JakeFusion's Avatar
Super Hulk Smash
No RTV. I used a new crank seal when I put the motor back together. I haven't had any leaks.
Old Jul 1, 2015 | 07:59 AM
  #50
vettenuts's Avatar
The stock bolt has sealant under the head. The ARP bolt is finely machined and seals. I have had mine on there for years, no leaks at all.
