The teardown begins....and already finding and handful of problems...
Old May 9, 2004 | 01:51 AM
verbs's Avatar
Default The teardown begins....and already finding and handful of problems...
Problems found so far:
1. Front Hal Series R shocks are both leaking (only 1000 miles on em )
2. Air plug from the back of the intake manifold fell off (I found it sitting on my tranny last week when fixing a Chevy dealership **** up from when they fixed my A/C).....so basically I had a vacuum leak on the car for a while.
3. Tranny seal where the driveshaft slides in is pretty destroyed. I haven't noticed leaking, but it needs repair.
4. U-Joint is very beat up....and in addition 2 of the bearings were floating around in the U-joint caps. Probably what was causing a vibration between 70-80mph upon mild acceleration.
5. Custom bolt setup from a crappy performance shop- I had 4 different stripped bolts on my U-joint. Made it a pita to take off
6. Exhaust leaks in some of the welds on my true dual exhaust (3 yrs old)
I'll keep everyone updated as it continues.....
Old May 9, 2004 | 11:11 AM
BTL FED's Avatar
I will never put another Hal shock on my car, with less that 1000 miles on my shocks 3 of them were leaking, and just for those that ask I never turned the adjustment know too far Afco's all the way for me now
Old May 9, 2004 | 12:08 PM
NicD's Avatar
7 Second Club
Haha, I don't know how many times I said don't buy those piles of **** shocks. Leaking garbage.
Old May 9, 2004 | 12:19 PM
gun5l1ng3r's Avatar
Where do you buy Afco's?
Old May 9, 2004 | 12:22 PM
Linear Velocity's Avatar
Haha no seriously verbs, when was the last time you had your car looked at? That seems like a lot of little things but I would still think if you had your car worked on in the last couplle months that someone would have something. You think any of things were costing you hp? Good luck.
Old May 9, 2004 | 12:24 PM
verbs's Avatar
Thx for the caring words
I don't think any of those things were costing me power; I'm still putting my money on the heads which will be on there way to TEA for inspection.
Old May 9, 2004 | 12:30 PM
Beast96Z's Avatar
Any reason why you didn't leave the shocks all hooked up and unbolt from shock tower? Seems like it would save a little time. Just wondering cause I'm fixing to drop mine out the bottom.
Old May 9, 2004 | 01:44 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
If you ran around with the shocks at full soft to impress the young guys at Sonic then you can rupture the seals.
I have 15,000 on mine and I have gotten air with mine many times, I always put them back at 6 or 7 for the street. Mine are fine.
Old May 9, 2004 | 01:52 PM
y2khawk's Avatar
http://www.billingsleyracing.biz/
Old May 9, 2004 | 06:09 PM
BTL FED's Avatar
Sorry never ran mine at full soft, I dont drive around trying to impress anyone. Usually my fronts were 4-5 and my rears were 6
Old May 9, 2004 | 06:10 PM
BTL FED's Avatar
Originally Posted by y2khawk
What he said, amber and jay are GREAT to deal with
Old May 9, 2004 | 06:38 PM
pdd's Avatar
pdd
A least u have a nice lift to work on. good luck with the repairs. i just bought a set of HAL adjustable shocks. hope they dont leak
Old May 9, 2004 | 08:02 PM
BTL FED's Avatar
That is a picture of my afco, and I just work off jackstands
Old May 9, 2004 | 10:52 PM
verbs's Avatar
My car has only seen full soft for one drag pass at the track. It has never seen anything else other than 6-7 on the street.
Old May 11, 2004 | 09:26 AM
CHRISPY's Avatar
If you were running around with a vac leak that explains many things right there. I am surprised you didnt notice your LTRIMS through the roof. That can EASILY account for 20 or more RWHP on the dyno in your setup.
Old May 11, 2004 | 10:12 AM
verbs's Avatar
The vacuum leak was very recent; I did notice the car not idling properly but figured since the teardown was coming soon anyway I'd deal with it then
Old May 11, 2004 | 10:42 AM
Todd@AZPowerAndSound's Avatar
is your other problem on the hush?
Old May 11, 2004 | 11:32 AM
NicD's Avatar
7 Second Club
I think so.
Old May 11, 2004 | 12:33 PM
JF WS6's Avatar
Originally Posted by Nic00Z28M6
I think so.
Well, now that you mentioned something you HAVE to spill the beans. Enquiring minds want to know.......
Old May 11, 2004 | 05:47 PM
angst911's Avatar
glad to see I'm not the only one with the adjustment all the way up on the sping seat.....
