Iron heads?
Old Dec 27, 2013 | 04:55 PM
ncperformance's Avatar
Default Iron heads?
I've heard rumor of some early LS engines with iron heads. Anyone know if these exist and if so where to score a set. Trying to fit an LS into a certain class that requires iron heads. Thanks
Old Dec 27, 2013 | 04:58 PM
HCI2000SS's Avatar
I thought they all were aluminum, but I can't say that with 100% certainty
Old Dec 27, 2013 | 07:17 PM
96capricemgr's Avatar
Some early truck engines, maybe even just early 6.0l
Old Dec 27, 2013 | 08:12 PM
CattleAc's Avatar
All the 99 truck 6.0's that I've seen have iron heads.
Old Dec 27, 2013 | 09:44 PM
jrpimp00's Avatar
No LS engines but the early LQ engines did
Old Dec 27, 2013 | 11:16 PM
cosbysweater's Avatar
Also the early 6.0 truck motor has a different crankshaft if I remember right
Old Dec 27, 2013 | 11:43 PM
1FastBrick's Avatar
The early LQ4 6.0L from 99-00 had a cast iron head. They are an LS based platforum.
Since you didn't post your location, Look on ebay.
The head casting on the end of the iron head is 873.
Old Dec 28, 2013 | 07:05 AM
Paul Bell's Avatar
That's MISTER MODERATOR
LQ4/9 engines are part of the LS engine series.
Old Dec 28, 2013 | 01:09 PM
rlane5's Avatar
I have a set that cam off my LQ4
Randy
Old Dec 28, 2013 | 04:48 PM
Paul Bell's Avatar
Welcome Randy!
Almost three years with us an this is your first post?
Let's see some more of you!
Old Dec 28, 2013 | 04:51 PM
Thanks for the help guys. I just may be able to piece this puzzle together. You want to sell that set Randy?
Old Dec 28, 2013 | 09:20 PM
vht's Avatar
vht
I know 99, 2000 truck 6.0 has iron heads. 5.3's are alum.
Old Dec 28, 2013 | 09:29 PM
subeone's Avatar
i have a set here in my house from an lq4 99
Old Dec 28, 2013 | 10:10 PM
rlane5's Avatar
Paul, Thanks for the welcome. I'm on this site, often, like you just said, I never posted on this site. I post on the corvette forum most of the time. I join this site a few years ago, to gain knowledge, on how to do a LS swap for my 86 vette, which I swap a LQ4 in it.
Randy
Old Dec 28, 2013 | 10:19 PM
rlane5's Avatar
I plan on selling the heads soon, I going to put some 243 or 799 ported heads on the engine. The engine was a Jasper rebuilt engine, that i brought from a guy that his truck was wrecked, so he pulled the engine out and sold it to me.
Randy
Old Jan 5, 2014 | 04:59 PM
Modis500's Avatar
The coolest LS piece I've seen was a cast alum intake manifold with a date of 10/93 on it. True GM piece one of the SAM students got out of GM and brought back to school to show off. I didn't know they were working on LS way back in the early 90's.
Old Jan 5, 2014 | 06:25 PM
2002 blue z28's Avatar
I was under the impression that all LS style engines had aluminum heads.
Old Jan 5, 2014 | 06:50 PM
The LS was debuted the Vette in 97. 93 is only 4 years earlier OEMs put a lot of time into clean slate engine designs, figure not just starting to make parts but durability tests and all.
Old Jan 5, 2014 | 09:34 PM
SthTxLQ4's Avatar
Ive got a 2000 lq4 with iron heads. The upside is it basically bolts straight up to the old 700r4 with no spacer due to the longer crank. The down side is I'd sure like to have a motor with aluminum heads for a change after stepping up from the old school garbage.
