Ls1 swap /build
Old Dec 31, 2013 | 07:42 PM
Zax570z's Avatar
Default Ls1 swap /build
New member here long time
Lurker , i recently purchased a 02 ls1 with 60k miles on it , looking to swap it into a non ls1 car ,
My goals are about 450-500 rwhp
My questions is with my power goal in mind , should i keep the stock bottom end or go ahead and invest in forged internals ?
My main worry is longevity with keeping the stock bottom end , and if i do keep it , should i at least replace piston rings? Bearings ? Cam bearings?
Theres no obvious signs of bluing on the cam bearings but i feel like i should replace them since i plan on going with an aftermarket cam.
If i replace those i do beleive i must take out the pistons ,by taking apart the caps on the rods and removing pistons can this affect my chances of ring failure later?
Its my first time building a motor from the bottom up so i have my flame suit on.
Old Dec 31, 2013 | 07:49 PM
HCI2000SS's Avatar
Stock bottom end will be fine at that power level if it's in decent shape
Old Dec 31, 2013 | 08:31 PM
Zax570z's Avatar
How can i tell exactly what needs replaced?
And should i replace the rings at least while its in shortblock form?
Old Dec 31, 2013 | 08:59 PM
cosbysweater's Avatar
Did you do a leak down or compression test? If leak down and compression is good, and the cross hatch is still good I wouldn't mess with the rings, just roll in some new bearings at the most and be done with it. These motors are pretty robust if they are taken care of and abused properly
Old Dec 31, 2013 | 10:22 PM
Zax570z's Avatar
The motor is only semi complete I got it in pieces the heads were off when I got it but only for packaging and sale. So can't really compression check it ... Crosshatch looks good though , I will also say that the motor looks very clean inside and out , no oil on block , inside is a slight golden brown no sludge anywhere .
I may have made a rookie mistake though ......
I cleaned the old head gasket off and now I have shavings I can see in the cylinder walls and coolant passages , can I clean that out and be ok and what's the best way to go about it? I was going to use compressed air and a shop vac mainly to get it out .
Also would pics help?
Old Jan 1, 2014 | 04:58 PM
Zax570z's Avatar
Ls1 swap /build-image.jpg
Also have some pitting in the block is this normal for aluminum ?
Old Jan 1, 2014 | 05:01 PM
Zax570z's Avatar
Old Jan 1, 2014 | 05:15 PM
Ummm what did you clean the deck with? And I would just blow it out with compressed air
Old Jan 1, 2014 | 05:37 PM
Zax570z's Avatar
Green roll disc tried to go lightly couldn't find any white discs
Old Jan 1, 2014 | 05:38 PM
Zax570z's Avatar
Also what's my best option for replacing cam bearings should I take it to machine shop or buy the tool
Old Jan 3, 2014 | 12:18 PM
jmac636's Avatar
It would cost about the same or a little more by the time you buy the tool and install the bearings yourself. Cam bearings are the one and only thing I have a machine shop do when no machine work is required. I say let them do it since they have way more experience.
